Multi-amping Troels Gravesen's OBL-11 - diyAudio
Old 8th April 2014, 03:03 PM   #1
Default Multi-amping Troels Gravesen's OBL-11
I am building Troels' OBL11 (OBL11), and recently the multi-amping idea arised in my mind. Since the speaker is fairly efficient (ca 95dB), the required power should be managable. Troels' comment on powering OBL-11:
Can the OBL-11 be driven from your 8 wpc 300B amp? Yes, if you don't play particularly loud. Does the Audio Mirror 20 wpc amps sound more dynamic? Yes. Does the Jungson amp - 80 wpc - really kick butt? Yes!
I will be using a DSP based crossover with one DAC per amp (for a 3-way: 6 DACs, based on the T-DAC design (RPi-DAC - Dual Mono)), so the last part that needs to be figured out are the amps.
I have been studying various approaches, but before I start rambling with my own half-done ideas, I'd like to ask what would you guys (and girls) suggest.
So, the question is:
how would you choose the amps for this particular application?
Cost can be regarded as a secondary constraint, but the solution should be DIY, based on commercially available components.
Primary objective is best possible sound (dynamic range/SNR/THD), and the deterministic use case (it is known that the amp is driving a single, predefined chassis).
I'm looking forward to new ideas!
Cheers
Nikola
OBL-11 Troels Gravesen, open baffle, loudspeakers, high efficiency Goflyshirley Swap Meet 10 10th January 2014 10:11 AM
Completed Troels Gravesen bookshelf speakers eboz Swap Meet 6 4th February 2013 09:49 PM
Any Experience with Troels Gravesen Designs??? mlammert Multi-Way 57 12th December 2012 02:53 AM
Troels gravesen PMS: riddle this for me matsuru Multi-Way 3 5th January 2008 01:45 PM
Copyright 1999-2017 diyAudio
