Chip amp comparable to class a sound - diyAudio
Old 28th March 2014, 05:02 AM   #1
Smile Chip amp comparable to class a sound
Hi All diy buddies,
I am new in this form, this is my first post,i want to know, is there any chip amp that sound quality is comparable to class a amp, i know class a sounds incredible but i wants to build a cheap IC amp [15 Watts to 50 Watts] that gives good sound quality.
If you have compared IC amp with class a [in sound quality] then please mention.
thanks,
Old 28th March 2014, 09:07 AM   #2
As far as I know there are no ClassA power amp ICs.
There are a (very) few ClassA buffers and opamps.
regards Andrew T.
Old 28th March 2014, 09:15 AM   #3
Mooly's Avatar
Moved to chip amps forum
Class A in itself is no guarantee of good or great sound quality and brings with it its own problems such as heat and power consumption and (comparatively) low available power outputs.
I would suggest you look at some of the LM3886 designs as an example of a good chip amp.
A simulation free zone. Design it, build it, test it.
Old 28th March 2014, 09:46 AM   #4
@mooly, i want sound with great dynamics for listening does LM3886 gives good dynamic sound or LM1875, i find good reviews on LM1875.
Pls suggest me :-)
Old 28th March 2014, 09:52 AM   #5
picowallspeaker's Avatar
May I repeat the obvious
That the amplifier-speaker-environment
Not to mention distance from, ehm, speakers
It has many many variables
Eminently non-electrical
Old 28th March 2014, 11:01 AM   #6
weskoki is offline weskoki  Europe
weskoki's Avatar
You could try the myrefc 3886 or the mini version.Its dynamic and detailed.
MiniRef Schematic and PCB layout
Old 28th March 2014, 11:10 AM   #7
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
TDA8566 is the chip which for me closest approaches the classA sound. Provided the power supply has plenty of low impedance caps across it that is.
It doesn't have to take the form of a conspiracy, rather a consensus... James H Kunstler
Old 28th March 2014, 12:24 PM   #8
Mooly's Avatar
Pls suggest me :-)
Both are highly regarded IC's. I can't give you a personal recommend because I have never built a chip... I prefer discrete designs.
Old 28th March 2014, 01:14 PM   #9
jacques antoine's Avatar
Isn't TDA8566 a class B chip?
Old 28th March 2014, 01:18 PM   #10
Mooly's Avatar
Probably nearer AB than true B.
Does Class A have a "different" sound to Class AB ?
can a class D amp gives enough dynamic sound as a good class AB? rhythmsandy Solid State 6 28th January 2013 01:59 PM
Which sound card has an SPDIF output comparable to an expensive CD Player? momitko Digital Line Level 68 31st May 2011 01:52 AM
class A cheap chip amp wahab Chip Amps 0 19th January 2010 09:44 PM
class d chip amp sagarverma Chip Amps 19 23rd October 2005 05:08 PM
new class T chip amp JZatopa Class D 1 17th October 2005 10:05 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
