| Chip Amps Amplifiers based on integrated circuits |
i have a 150w 4ohm speaker and two tda1514a's.Briged both microshem can deliver on 4 ohm load and 25v about 120 w maybe more.What shall i do?: put on output 4ohm resistor with speaker or tda1514a can hold 2ohm each?
#2 |
maybe it would be better to use about +/- 20 volts and use 4 ohm load(2 ohm for each tda1514)
#3 |
May be you can try them in parallel mode! With +/- 23v PSU TDA1514A can drive 48W to a 4ohm load. And if u connect them in parallel u can feed them with +/- 28v. In that case they will give about 85W RMS to a 4 ohm load.
#4 |
if i use bridge with 4 ohms load and +/-25volt and put heatsink with cooler 0.6°C/W 2xtda1514 wouldn't fail even on 140 Watt load!!??
#5 |
I tried one TDA1514A with 4ohm load and sym 26v PSU. It was hot as a hell! How can u do that? Doesnt SOAR and thermal protection get active?
#6 |
i'll put heatsink and cooler about 0.6°C/W.I think this should do it.
Bytheway 0.6°C/W can hold AMD palomino with 70watts dissipation. |
#7 | |
Dxvideo wrote:
#8 |
15x20cm standard passive alu hetasink.
| Bridged 4780 for 4ohms load? | jaste | Chip Amps | 18 | 26th May 2010 04:46 PM |
| .. are TDA1514a **** or what ..?? | tmyr | Chip Amps | 1 | 1st December 2006 07:06 PM |
| TDA1514a amp | jez | Chip Amps | 5 | 17th April 2006 08:19 PM |
| P3A Bridged Into 4 Ohm load | kinser | Solid State | 0 | 12th August 2005 01:09 PM |
| Bridged and Parralleled to drive two ohm load | Matttcattt | Chip Amps | 18 | 2nd February 2004 08:58 PM |
