The LM6171 is a rocket opamp and while you can 'tame' it for audio use, you're not going to achieve that with single sided boards. For that chip I'd use a 4 layer board with an internal ground plane. Amplifiers that fast behave much better at lower impedances. Stuff you can 'get away' with in audio with slower amps won't cut it with 100MHz GBP and 3600 V/uS.
Pick a more appropriate amplifier. There are many to choose from.
G²
G²
hi john i posted a picture of my circuit
You posted a PCB layout - I was referring to a schematic - but even looking at the PCB layout and the PCB tracks on the non inverting pin (Pin2) of the Opamp are far to long - with the resultant capacitance that will upset high speed opamps.
