7294 chip went bang??? - diyAudio
Old 12th March 2014, 05:13 PM   #1
radiosmuck's Avatar
Default 7294 chip went bang???
I have just purchased a stereo 7294 board that required me to add a heatsink, which I did!
The amp was working well for quite a while until I touched the heatsink to check the temperature. There was a flash, bang and a plume of smoke.
On checking the blown chip I noticed that I had not installed the mica insulator quite parallel the the chip body.
Winters are very dry here and static shocks are regular when touching a water tap or radiator. Is it possible that when I touched the heatsink a spark jumped the gap between it and the chip where there was no insulation?
Thanks.
Old 12th March 2014, 05:42 PM   #2
ashok's Avatar
Originally Posted by radiosmuck View Post
....Is it possible that when I touched the heatsink a spark jumped the gap between it and the chip where there was no insulation?.....
I doubt it. However it might have caused a spike on the ground line killing the chip. This chip IS sensitive to anything beyond what they strictly specify. So maybe lifting the ground momentarily caused something to blow on the chip.
Remember that the spark is between the hand and the heatsink. However it could cause a momentary disastrous voltage spike on the ground line !
AM
Old 13th March 2014, 02:24 AM   #3
dipolar is offline dipolar  India
dipolar's Avatar
Could this be a case of fake TDA7294?
Mine was purchased Locally in December, Used for 4ohm 12" Subwoofer with 2sc5200/1943 boosters.
It sounded pretty powerful and satisfactory with 36-0-36 volts dc input and a generous heatsink.A day of operation would make it warm(I can keep my hands on Heatsink without any casuality. viz50-60 degree celcius)
Approximately after 5 weeks there was only a loud buzz in woofer .I desoldered the chip and found output pin 13 and pin 15 has shorted. Output transistors are still intact.
No act of kindness, no matter how small, is ever wasted.
Old 13th March 2014, 02:38 AM   #4
It depends on where you purchased it, if you bought it from TayDay in china, or some place like that then all bets are off. Even local suppliers can bulk purchase these from places like this for peanuts, and you get fakes. Ideally you want a reputable supplier.
But the TDA7294 in itself is an overly sensitive component. I have seen many amplifiers and subwoofers built around that IC, even Bose, failed with no rhyme or reason as to why. One minute they work, and the next minute they spontaneously combust and I have seen something as simple as a power-on transition explode these ICs. I stayed away from this IC and avoided it like the plague. That goes with most of STs products.
Old 13th March 2014, 03:11 AM   #5
dipolar's Avatar
Thanks for quick response.
I have used a power on transistor at mute pin for soft start and quick turn off.
Is there a way to identify fake TDA7294 from the batch code ,I have tested pin 11 and 12 method.?
Old 13th March 2014, 03:41 AM   #6
ashok's Avatar
Where do you take your drive for the power transistors ? A single resistor from the 7294 output or two resistors one on each the supply rail ?
If it's the latter , you are in a position that any glitch on the output 'could' cause failure.
AM
Old 13th March 2014, 03:55 AM   #7
dipolar's Avatar
This is how power transistors are configured.
It worked 5 weeks perfectly,went off while turning on next day( so no thermal runaway or short circuits.)
Old 13th March 2014, 04:34 AM   #8
danielwritesbac's Avatar
It is easier to identify a real TDA7293 because all 15 pins work in the real thing.
Problematically, the datasheet schema for TDA7293/4/5/6 tends to make them under-perform and eventually quit.
Suggestion: Treat the fake TDA7294 as if TDA7296--much lower power voltage.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 13th March 2014, 07:12 AM   #9
Mark Whitney's Avatar
Could most of these failures be caused by bad insulation between chip and heatsink? Negative rail and ground are only separated by a thin insulator. The current would only be limited by the PSU.
Regards Mark.
Old 13th March 2014, 07:53 AM   #10
ashok's Avatar
Originally Posted by jayadev View Post
......went off while turning on next day.........
Your output stage is OK and the rails of your input and output must be connected directly. So one possibility is that your supply rails didn't come up together ( or go down together when last switched off ....maybe like power off when music is playing loud !). I think the chip is sensitive to this.
Wish Ilimzn is reading this. You could search for him and send him a message. He understands this chip well.
AM
PCB TDA 7294 CristianValentin Chip Amps 5 24th July 2014 04:34 AM
Question about this 7294 amp Elkaid Solid State 22 3rd February 2010 03:03 PM
Amp on TDA 7294 maris24 Chip Amps 4 17th November 2006 10:11 AM
TDA 7294 Subwoofer rehanabid Chip Amps 6 18th December 2003 03:36 PM
Copyright 1999-2017 diyAudio
