lm386 speech amplification and filter circuit - diyAudio
Old 1st March 2014, 11:10 AM   #1
Default lm386 speech amplification and filter circuit
I am using lm386 for signal amplification recievied from microphone and then send them to analog pin of arduino..do i need a speech filter circuit also between lm386 and arduino or lm386 would limit the frequency response to 300-3400hz (the speech audio spectrum range)??....
{ basically i am trying to make a audio recorder..the arduino will store the data in a wav file and transfer it to sd-card for playback }..
Old 1st March 2014, 01:59 PM   #2
frank1 is offline frank1  United Kingdom
The LM386 is a small power amp. It will be very noisy used as a Mic amp.
As with any A-D conversion, you will need a LP filter to prevent aliasing.
Frank.
Yamaha's Hyperbolic Conversion Amplification (HCA) Circuit tiefbassuebertr Solid State 115 22nd November 2016 03:42 PM
Speech Amp for Modulator WZ5Q Tubes / Valves 18 16th December 2014 02:09 AM
Bi-amplification to Dx Amplifiers, a passive input filter destroyer X Solid State 53 17th July 2009 06:16 PM
Copyright 1999-2017 diyAudio
