diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Chip Amps (http://www.diyaudio.com/forums/chip-amps/)
-   -   Digital Volume Control (http://www.diyaudio.com/forums/chip-amps/25196-digital-volume-control.html)
soundNERD 2nd January 2004 12:48 PM
Can I use the LM1972, at http://www.national.com/pf/LM/LM1972.html and control it with two pushbuttons, one for up and one for down?
If not, would any National, Maxim or TI chip (I would like to get samples) work for what I want to do?
Thanks, Mike
mhennessy 2nd January 2004 01:42 PM
Re: Digital Volume Control
Thanks, Mike
No, you would need a microcontroller (such as a PIC or AVR) to generate the serial data required by most of these devices. Checking the datasheets will tell you all you need to know about the format and timing, etc...
An exception to this is the Dallas DS1802, which can be controlled by pushbuttons. I considered it for use in my preamp, you can read what I though here: http://www.mhennessy.f9.co.uk/preamp...e_research.htm
Mark ;)
deandob 2nd January 2004 08:01 PM
PIC volume control
I have a working PIC schematic & code for the LM1972 as a volume control - if needed I can email it to you. The code allows the PIC to be connected to a PC serial port & control the volume through software on a PC.
Dean
Matttcattt 3rd January 2004 12:24 PM
Re: PIC volume control
Dean
Could you e-mail me the info also? matttcattt@yahoo.co.uk
jackinnj 3rd January 2004 01:16 PM
Re: Re: Digital Volume Control
Mark ;)
No you don't need a microcontroller -- but it is easier with one -- the LM1971,2,3 are synchronous devices so you either toggle the clock line yourself or use a slow-moving 555, an 8-bit "counter" and a "Parallel in Serial Out" shift register (74HC595) -- bring the Load line "LOW", set the address of the LM1972 (0,1,2), by transmitting 8 bits, then transmit the dB/mute setting (second 8-bits), bring the Load Line "High". Parts to do this are about $1.00.
If using a pushbutton for up down, consider how many milliseconds you want the '555 to run for the full gamut.
"Software" in solder -- the old fashioned way -- still works as Steve Ciarcia is wont to say.
deandob 3rd January 2004 07:58 PM
matttcatt, you have mail.
Dean
soundNERD 3rd January 2004 08:17 PM
First, I ordered a sample of the dallas chip.
Second, I would like that microcontroller volume control code and schematic.
e-mail me at webmaster@electronet.5u.com
Thanks!
TheTrax 3rd January 2004 08:24 PM
Hi
can you tell me the chip type number and the kind of microprocessor you want to use ?
I can help you making ASM assembler routines if you want ?
soundNERD 4th January 2004 04:00 AM
Well, i donno 2 much about microcontrollers. 2 be honest, ive never used one before. So, whatever is cheap and can be eaily bought. (as always i like free samples).
-Mike
koolscooby 4th January 2004 04:05 AM
Mark ;)
And let me add, that your pre-amp is really hardcore-style-awesome :)... i plan to build something similar to it when i have abilities even close to yours ;)
Resources saved on this page: MySQL 18.75%
