Old 6th September 2004, 02:36 PM   #51
I would be interested in a copy of the schematic also, if it is still available. E-mail address is- mrskinny@3web.net Thank you!
Old 6th September 2004, 02:45 PM   #52
li_gangyi's Avatar
in ur last schematic (which I saw) on http://www.diyaudio.com/forums/attac...&postid=295126
you forgot the gain setting resistos from the output to the negative input of the opamp...put that in place and I believe it should work...test the opamp section and make sure it's working BEFORE sticking the transistors in...
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 17th January 2012, 01:36 PM   #53
Adi_007 is offline Adi_007  Romania
hi, which is the recommended power supply for LM1875 in bridge mode?....is +/-21Vcc enough or is to much......this amplifier will be used with 8ohm speakers
Old 17th January 2012, 03:10 PM   #54
johnr66 is offline johnr66  United States
I'd go +/- 18 volts or so (under load). Mount the chips direct on the heatsink as well as they'll need to dissipate a lot of heat for that package style. The tab insulator adds thermal resistance. If you must have an isolated heatsink, use a heat spreader that is electrically isolated from the main heat sink. Consider the TDA2050 as it is rated at 5 amp max current.
BrianGT LM1875 feedback capacitor question Sparky OR Chip Amps 13 31st December 2008 05:54 PM
LM1875 power supply question (easy) madisonears Chip Amps 12 24th February 2008 10:41 AM
2 general gainclone questions, and an lm1875 question Adam M. Chip Amps 11 4th March 2005 11:53 AM
LM1875 battery question Fragen Chip Amps 17 14th October 2004 09:58 AM
Page generated in 0.12904 seconds (48.32% PHP - 51.68% MySQL) with 11 queries
