| Chip Amps Amplifiers based on integrated circuits |
I just recieved two LM3875T's today and I really want to test one out but I a bit short on resistors and capacitors. I've attached a schematic with some stuff circled and I was wondering if it's absolutely necessary to include them in this schematic or if I should buy everything I need before I attempt anything.
#2 |
Most of those components are essential.
#3 |
Rin is a volume control
Rb is to reduce DC offset Cs is supply filtering Rfi and Ri are gain setting resistors and Rfi/Ri > 10 Ci is to reduce DC offset
if only it could be used for good, not evil... |
#4 | |
C1 not needed and RL is your speaker. The rest of them, unfortunatley ablolutely have to be there. |
#5 |
Banned
you could exclude the volume control if you are able to run the amp from the headphone socket of something....
#6 |
diyAudio Moderator Emeritus
If you omit the parts you describe you better omit the LM3875 too
It's only audio |
#7 |
Rfi and Ri are to determine voltage gain. Its OK! But What Ci makes? If we ommit that what happens?
#8 |
In the UK, the first day of April is called April Fools day when people play a lot of silly pranks. Reading some of the posts here this morning it looks as though the last day of December is the equivalent in the US!
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#9 | |
Edit: I have left off RB before with no obvious problem.
Best-ever T/S parameter spreadsheet. http://www.diyaudio.com/forums/multi...tml#post353269 |
#10 | |
You will have quite a DC offset if you short Rb and short C1 at the same time. If C1 is there, Rb is not that critical. |
| Caps coils and resistors | guru_jeff | Multi-Way | 2 | 20th June 2010 06:39 PM |
| Various FS:esp boards/caps/resistors UK | RobWells | Swap Meet | 17 | 23rd April 2005 10:28 AM |
| Are these Caps or Resistors? | octopus | Multi-Way | 9 | 17th July 2003 01:24 PM |
| Non inductive caps and resistors | Super | Parts | 5 | 12th November 2001 12:06 AM |
| Page generated in 0.13685 seconds (72.69% PHP - 27.31% MySQL) with 11 queries |
