Improving the LM3886 amplifier - diyAudio
Old 29th January 2014, 09:06 PM   #1
FOXYE is offline FOXYE  Israel
Default Improving the LM3886 amplifier
Hello,
Currently listening with LM3886 amplifier 20,000μF for each side in the psu.
The sound is very detailed, and have dark sound signature.
But the highs is not pleasant and the mids is laid back.
In summary the sound not "live" as the great LM1875.
Are there any recommendations how to improve the LM3886?
Schematic of amplifier:
Old 29th January 2014, 09:48 PM   #2
Robert Kesh's Avatar
Isn't R12 meant to be as close to the pins as possible?
Old 29th January 2014, 10:03 PM   #3
KatieandDad's Avatar
I too found the LM3886 a bit dull when compared to the true greats of the audio world. It is cheap and it is easy for those on a limited budget but it can be bettered many times over by discrete circuit designs.
Old 29th January 2014, 10:04 PM   #4
lanchile's Avatar
I second that!
Make it simple...Make it better!
Old 29th January 2014, 10:33 PM   #5
Originally Posted by lanchile View Post
I second that!
Every thread in the Chip Amp forum has to have, by law, at least one post about discretes being better.
Old 29th January 2014, 11:54 PM   #6
That PCB layout looks terrible, the bypass caps are too small and too far away from the chip pins. I recommend checking for HF oscillation or transient circuit instability.
Mike
Old 30th January 2014, 12:09 AM   #7
Banned
Do you mean as in thread-jacking a thread that is only about a chip amp? Does that happen here? Surely not!
FOXYE, do you have a schematic and a photo of the entire amp?
Abs
Old 30th January 2014, 12:18 AM   #8
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
The most common mistake I've seen with chipamps is in the layout - poor gronding hygiene. Not keeping signal and power grounds separate IOW.
Show a schematic for how the decoupling caps are wired up, topologically?
No matter if we meanwhile surrender every value for which we stand, we must strive to cajole the majority into imagining itself on our side - Everett Dean Martin
Old 30th January 2014, 12:28 AM   #9
yd1cvj is offline yd1cvj  Indonesia
C6, input cap, you can up grade .
C11, C12 are too small , increase to 1000 microF with C for audio.
Old 30th January 2014, 12:29 AM   #10
Hello,
But the highs is not pleasant...
I've said it before and I'll say it again, this amplifier needs to have feedback compensation. Try a 27pf capacitor in parallel with R10 and see if there's an improvement.
Also, not helping things is that this layout is terrible, rip out the two small decoupling caps and place them right on the chips pins. 100nF X7R caps are perfect for this job.
I hope this helps.
How does the power supply look? Schematic please
Improving amplifier input stage stevensoosai2527 Solid State 5 8th December 2012 09:54 AM
Suggestions needed for improving Rogers Cadet II PP power amplifier Sanjiv Sahgal Tubes / Valves 10 23rd May 2012 09:26 AM
improving amplifier transients by large capacitor banks muddasirwaheedmalik Car Audio 17 16th September 2011 09:06 PM
Improving Heatsinks for an Amplifier? pjpoes Parts 23 31st December 2007 05:50 PM
LM3886 Amplifier help Jack Bruce Chip Amps 3 16th January 2007 12:25 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
