Speaker/chip amp 'compatibility?
Old 27th January 2014, 10:21 AM   #1
fap is offline fap  Australia
Default Speaker/chip amp 'compatibility?
G'day all, I've recently encountered a very strange speaker/chip amp compatibility issue that is nothing short of bizarre!
A set of Jaycar JV60 speakers that I recently purchased pre-assembled simply will not work with my old reliable LM3886 amplifier (the ESP P19 design), without producing severe audio distortion (well below clipping), yet my existing good quality bookshelf speakers work fine without 'any' distortion with this same LM3886 amplifier!
However the same JV60's work fine with a lower power chip amp using an LM1875T chip. I simply cannot think of any technical reason why the JV60's will not apparently work with my LM3886 amplifier! Could there be some kind of curious speaker/chip amplifier incompatibility? Regards, Felix.
Old 27th January 2014, 10:22 AM   #2
R.I.P.
Have you fitted all the stability enhancing "optional" components to both versions of your chipamps?
Have you fitted the two input filters to both versions of your chipamps?
regards Andrew T.
Old 27th January 2014, 10:26 AM   #3
G'day mate, yes all stability components have been included in my construction as far as I can recall. Yes, it's a strange one! Regards, Felix.
Old 27th January 2014, 10:47 AM   #4
R.I.P.
which construction includes all the "optional" components?
regards Andrew T.
Old 27th January 2014, 10:52 AM   #5
G'day mate, this one, it's actually the LM3876! Single Chip 50W Stereo Amplifier Regards, Felix.
Old 27th January 2014, 11:12 AM   #6
R.I.P.
Can you check for oscillation?
can you add a 0r22 power resistor to the output after the Zobel?
regards Andrew T.
Speaker/chip amp 'compatibility?Hide this!Advertise here!
3 way driver compatibility check: first time speaker builder fishish1 Multi-Way 18 21st September 2011 06:39 PM
Chip amp to use with Tivoli speaker kenneth Chip Amps 4 17th February 2009 09:07 AM
Best Chip amp for this 4 Ohm speaker 100db Chip Amps 14 29th September 2006 12:45 AM
Gainclone -- speaker, cable compatibility??? greg7 Chip Amps 17 20th May 2003 09:49 AM
