4 TDA2050 in parallel array ? 120w mono ? - diyAudio
Old 24th January 2014, 07:30 PM   #1
johanx2 is offline johanx2  United States
Default 4 TDA2050 in parallel array ? 120w mono ?
Hi. I know that you can get 60w by bridging two of these chips. But what I don't know is if you can connect (maybe in parallel) more of these chips in order to get a mono amplifier with a total power of 120W. Please note that I'm not talking about stereo configuration. I have seen several circuits that uses many LM3885 or TDA7294 in order to get a lot of power in a mono configuration. Thanks.
Old 24th January 2014, 08:12 PM   #2
I don't see why not the same rules would apply for any other paralleled opamp design.
However being that they are only rated at +/- 25V you would only get +100 watts if you are using a 2 to 3 ohm load.
https://www.google.com/search?num=10...26.QgyVaRHW16E
jer
Simple TDA2050 mono amp for PC ToMiC Chip Amps 19 14th March 2011 11:04 PM
Replacing TDA2030a with TDA2050 in parallel hernanstafe Chip Amps 4 16th March 2007 01:52 AM
TDA2050 parallel. HELP! Matthewong Chip Amps 5 9th March 2006 03:47 AM
TDA2050 parallel. HELP! Matthewong Chip Amps 11 13th February 2006 02:11 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
