Good but simple subwoofer chip amp. circuit suggestion
Old 29th December 2003, 04:04 AM   #1
Alvin is offline Alvin  Hong Kong
Default Good but simple subwoofer chip amp. circuit suggestion
Hello,
I am planning to DIY a pair of active subwoofer using SS 25W/8565-01 as drivers.
The cabinet should be 50~60L vented.
Now, I am looking for the circuit that need to include:
1) the amplication, preferably using chip amp. (e.g. LM3875 or OPA549)
2) the equalization to equalize the not so smooth SPL
3) the active XO, better selectable.
Thanks very much!
Alvin.
Old 17th January 2004, 09:37 AM   #2
deandob is offline deandob  Australia
Default No interest?
I would have thought a DIY subwoofer amp would be a popular topic.
I have attached a 240w class-D schematic from a new philips chip TDS8924. This is attractive for a DIY subwoofer as it has a very low parts count (simple design), high power, acceptable performance, needs a small heatsink & small power supply. Only trouble is it is not available to purchase yet as the chip is new.
Dean
Old 17th January 2004, 01:04 PM   #3
soundNERD is offline soundNERD  United States
I use a 3886 built with the circuit on the 1st page of the datasheet.
Not too powerrful, but simple and does the job.
-mike
Good but simple subwoofer chip amp. circuit suggestionHide this!Advertise here!
Good Case for simple chip-amps lhwidget Chip Amps 3 10th October 2010 07:17 PM
Simple PCM2707 bus powered I2S source, is this circuit good or bad? JogeirEmil Digital Source 6 2nd December 2008 03:12 PM
good simple SE circuit please Raj1 Tubes / Valves 35 29th November 2003 09:14 PM
Whats a GOOD LM3875 chip amp circuit? matt_uk Chip Amps 5 14th November 2003 09:23 PM
Good & simple chip amp for 2-ohm load? Otherwise Chip Amps 7 8th July 2003 07:21 PM
Copyright ©1999-2017 diyAudio
