Rolling opamps: DIY DIP-14 to two DIP-8 socket converter for quad opamp to dual opamp
Old 16th January 2014, 05:23 AM   #1
ygg-it is offline ygg-it  Italy
ygg-it's Avatar
Thumbs up Rolling opamps: DIY DIP-14 to two DIP-8 socket converter for quad opamp to dual opamp
It is so hard to find in the market, that I decided to build myself.
Very useful for your listening tests and MODS.
This is a DIP-14 to two DIP-8 socket adapter to convert any quad opamp to two different dual opamps.
It contains also a 100nF rail-to-rail ceramic capacitor.
I'm permanently using in the pre-amplifier section of a Musical Fidelity A120 amplifier, where I temporary replaced JFET quad op-amp TL084 with two different superb bipolar chips (chosen after rolling several dual opamps, but still under listening test): Analog Device AD827 as unity gain buffer and Linear Technology LT1361 for volume gain.
To use this you need to unsolder your quad op-amp, that could be a tricky procedure.
Enjoy!
Old 17th January 2014, 05:25 AM   #2
ygg-it's Avatar
Default Another DIP8 combination
This is another outstanding bipolar configuration: Linear Technology LT1355 as unity gain buffer and Analog Device AD826 for volume gain.
Sound is slight less accurate and clean, but more emotional and warm-toned (thanks also to the well-known heavenly midrange of the AD826).
I stop here since the DIP8 combinations are nearly infinite..
Old 17th January 2014, 12:27 PM   #3
Nice.
Would even allow one of the pair to be a discrete opamp, or a discrete Buffer.
And allow for a soic to dip8 converter
regards Andrew T.
Rolling opamps: DIY DIP-14 to two DIP-8 socket converter for quad opamp to dual opampHide this!Advertise here!
Pass Discrete Opamp in DIP-8 Package EUVL Pass Labs 117 9th May 2017 02:25 PM
TO-99 vs DIP-8 Packing for LME49720 Opamp bburl Chip Amps 14 6th February 2010 09:20 PM
Heatsink for 8-DIP Opamp arupg Parts 20 14th August 2007 10:09 PM
single so8 to dual dip opamp adapter available from BrownDog morsel Solid State 18 1st June 2002 06:34 PM
Copyright ©1999-2017 diyAudio
