My 3886 Chip Amp PCB Layout
Old 28th December 2003, 05:38 PM   #1
lgreen is offline lgreen  United States
lgreen's Avatar
Default My 3886 Chip Amp PCB Layout
Below are pictures of my PCB layout for a stereo amp based on the 3886 chip (inverting configuration like Peter Daniel's and others). I'm just posting this to get comments from everyone prior to actually making the board. Do you think it will work? Obviously the values are not in there, but assume I use the standard values posted by I think Thor and Peter Daniel. This is done on Eagle.
The point of this PCB is to get something that works so I can play around with it a little and get familiar with chip amps. I don't have a rectifier board, this connects after the rectifiers.
1. In particular, are the pins of the 3886 chip connected correctly? I think that they are, and hope that I got the orientation correct. If you can verify this that would be great.
2. I have made this for a pcb mounted attenuator, but left connection points for external attenuators, so that is why you see extra points for "wiper" and such.
3. Also made a provision for a larger coupling capacitor, so you see an extra hole for that too.
Comments appreciated, and yes, this is my first ever PCB design.
Old 28th December 2003, 05:47 PM   #2
lgreen's Avatar
Default Overall Layout
Here is the overall layout.
On right side I think pin 1 is on top, and pin 11 on bottom, on left side I think pin 11 on top and pin 1 on bottom.
Old 28th December 2003, 05:52 PM   #3
lgreen's Avatar
Default Layers and Pads
Here are the layers and pads for a better view. Red is top layer, blue is bottom layer, the thick traces are .07 inches (1.778 mm).
Old 28th December 2003, 07:19 PM   #4
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
I think you should identify all high current traces and make them wider. The LM3886 can handle at least 11.5 A.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 35 pcb's in interest.
Old 29th December 2003, 12:01 AM   #5
lgreen's Avatar
Default How wide?
How wide should they be?
Old 29th December 2003, 12:04 AM   #6
SkinnyBoy is offline SkinnyBoy  Australia
Banned
Send a message via MSN to SkinnyBoy
probbaly 3 times as wide as they are now...
My 3886 Chip Amp PCB LayoutHide this!Advertise here!
Eagle vs. Sprint-Layout for PCB design/layout hollowman Parts 11 12th January 2014 09:01 PM
lm 3886 larryg Chip Amps 6 1st June 2009 06:38 PM
help with layout of multi-kit chip-amp pre-amp okapi Chip Amps 8 11th January 2007 11:03 PM
pre amp for 3886 bostonswoop Chip Amps 6 19th June 2006 02:58 PM
Impressions of Snubbered BrianGT 3886 vs Reg 3886 moving_electron Chip Amps 1 23rd March 2005 06:51 AM
