Pga2311 pic16f877 spi interface code
Old 4th January 2014, 09:35 PM   #1
kualrea is offline kualrea
Default Pga2311 pic16f877 spi interface code
Iwant to control the pga2311 with Pic16f877. Anyone have example c codes?
Old 4th January 2014, 11:04 PM   #2
geraldfryjr is offline geraldfryjr  United States
Hmmmmm....That looks much better than the LM1972's I just got !!!
Cheers !!
jer
Old 4th January 2014, 11:07 PM   #3
do you have any example code for spi control?
Old 5th January 2014, 02:50 PM   #4
playOvation is offline playOvation  Germany
playOvation's Avatar
Though I don't know much about PICs (my favourites are Atmel's µCs), there's a piece of advice I can give:
have a look into the PGA's datasheet at section "serial control port".
Everything you need is in there I did the same when building my preamp and it was done in less than 1 hour.
Good luck!
Old 10th January 2014, 10:32 PM   #5
anyone help?
with this code I can't control the pga2311.
#include <16f877A.h>
#fuses XT,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP,NOPUT,NOWRT,NO DEBUG,NOCPD
#use delay(clock=4000000)
#use rs232 (baud=9600, xmit=pin_C6, rcv=pin_C7, parity=N, stop=1)
#use spi (master, DI=pin_C2, DO=pin_C1, CLK=pin_C0 ,SAMPLE_RISE,bits=16,LSB_FIRST,IDLE=0)
#define CS PIN_C3 // CS ifadesi PIN_C2 pini yerine atanıyor
int16 N;
void main ()
setup_psp(PSP_DISABLED);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DISABLED,0,1);
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_CCP1(CCP_OFF);
setup_CCP2(CCP_OFF);
output_high(cs);
N=0;
while(1)
{ output_low(cs);
if (input(pin_A5))
{N=N+1;
output_low(cs);
delay_ms(20);
spi_xfer(N);
output_high(cs);
delay_ms(50);
Old 12th January 2014, 10:17 PM   #6
Obviously it isn't Where did you get that sourcecode? It looks a bit weird to communicate with a PGA2311.
Did you scope the bus already?
I suggest to build up your control word like that:
One Byte (let's call it "left") contains the volume for the left channel.
Another one (call it "right") represents the volume of the right channel.
Now you take a 16-bit variable (let's call it "volume") and do the following:
[pseudo code] volume = right*256 + left [/pseudo code]
Now you can transmit THIS variable via SPI to your PGA2311.
I hope, this short post will help you a bit
Pga2311 pic16f877 spi interface codeHide this!Advertise here!
PGA2311 code child1 Analog Line Level 12 27th January 2013 02:30 PM
Little USB/Digital interface box with I2S interface QA01 lxiaob Digital Source 0 2nd January 2013 05:51 AM
CS8406 SPI problem mstro Digital Line Level 11 30th August 2011 03:21 PM
Problem witht [code]blah[/code] ? elseif Forum Problems 1 17th August 2008 01:30 AM
cxa1244 SPI padamiecki Parts 0 29th March 2004 05:58 AM
Copyright ©1999-2017 diyAudio
