LM3886 Chip Amp Getting VERY HOt LM3886 Chip Amp Getting VERY HOt - Page 3 - diyAudio
Old 6th January 2014, 06:03 PM   #21
Michael Bean is offline Michael Bean  United States
Michael Bean's Avatar
That transformer will work just fine.
Mike
Old 7th January 2014, 03:27 PM   #22
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Dual secondary transformer with 8 of 4a diodes is okay, a bit max, but okay.
Center tap transformer with 4 of 10a diodes is okay and quite similar.
Center tap transformer with 4 of 4a diodes--those diodes aren't strong enough.
Next, the most common cause of overheating is too many duplicate grounds, aka ground loops. See Decibel Dungeon website for a briefing on star grounding.
You can: Strongly connect PG+ to PG- at the output of the power supply board to create a central ground, the 0V. You'll be needing a 0V.
Run one (1) wire from the 0V to each amplifier's CG port.
Run one (1) wire from the 0V to the speaker jack negative.
Now most of the ground loops are gone. It will probably quit overheating.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
LM3886 Chip Amp Getting VERY HOtHide this!Advertise here!
LM3886 chip amp help danielnaveen Chip Amps 31 31st January 2011 02:33 PM
First chip amp - lm3886 agithegreat Chip Amps 31 5th April 2010 03:35 PM
Chip amp lm3886 help needed!!! kanifee Chip Amps 7 23rd June 2008 09:01 PM
My LM3886 chip amp Denis.BR Chip Amps 13 19th October 2007 02:15 PM
My LM3886 Chip Amp bhk Chip Amps 9 22nd March 2006 12:33 AM
Copyright ©1999-2017 diyAudio
