LM4780 Mini amp - Completely DIY
Old 31st December 2013, 06:40 PM   #11
troystg is offline troystg  United States
troystg's Avatar
Looks very good... But I do hope you plan to use banana plugs... That would be tough to thread the wire / spades and tighten the binding posts...
But I love the compactness. For a setup and forget install it would be great!
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 31st December 2013, 06:40 PM   #12
kuroguy is offline kuroguy  Germany
kuroguy's Avatar
Not sure what's up with posting pictures, but i'll keep posting them as i proceed. The CNC was completely DIY and designed by me. The complete build log for the CNC is at Dave's made from samples benchtop router thread .
"The magnet wire used to come from Radio Shack. In keeping with their policy of figuring out what the best products are and discontinuing them they no longer have it." - Max Robinson
Old 31st December 2013, 06:45 PM   #13
kuroguy's Avatar
I wanted compact and this one will weigh in at 2" tall x 10" wide x 7" deep. Shouldn't be too difficult to hook up speakers (the trick is to rotate the posts 45 degrees) and since i'll only need to do it once, i figured no biggie.
I'm really happy with the panels. I figure having them made would have cost about $80. Materials were $4. Not bad considering the CNC only cost $600 to build.
Old 31st December 2013, 06:53 PM   #14
GOR3 is offline GOR3  United States
Very nice, indeed. At what rpm and feed-rate do you mill the holes?
George
Old 31st December 2013, 08:37 PM   #15
kuroguy's Avatar
I went slow: 15,000 rpm and 6"/minute with 0.005" depth of cut since it was my first time cutting aluminum. I can definately go deeper so i'll try 0.01 next time.
Old 31st December 2013, 10:35 PM   #16
ypaudio is offline ypaudio  Singapore
Wow..Cool man ! I see the led is not usual, where did you buy it?
I interest with your DIY CNC. Nice work
Old 31st December 2013, 10:38 PM   #17
kuroguy's Avatar
All parts came from mouser. Those LEDs were the cheapest they had. Here it is with 4 sides. All my projects get at least some wood and I like the look of stained plywood for the sides.
Old 1st January 2014, 01:41 AM   #18
No 4 is offline No 4  United States
Very nice. I too like the look of wood combined with metals. What are you using to finish the aluminum?
By the way...thanks for the link to cnczone....wow I know what I will be doing for a while
Will.
Old 1st January 2014, 02:56 AM   #19
kuroguy's Avatar
Just polishing the aluminum with rouge. It'll get an oxide layer which is pretty close to clear and then it won't tarnish anymore.
Old 1st January 2014, 10:22 PM   #20
kuroguy's Avatar
Power transformer installed and wired. Input section wired. Output zobel wired.
LM4780 Mini amp - Completely DIYHide this!Advertise here!
Completely Clueless! DIY Audio: Step 1 emmarw Multi-Way 7 25th June 2013 04:28 PM
HiFi DIY's mini-A kit amp acebritbiker Solid State 17 3rd May 2013 11:11 AM
DIY 50C5 mini amp... nige838 Tubes / Valves 19 30th October 2010 10:23 AM
High Efficiency Mini DIY Speakers for T-amp DreadPirate Multi-Way 7 6th February 2009 02:48 AM
Mini Ipod headphone amp DIY project Nordic Headphone Systems 14 11th March 2007 03:35 PM
