LM338 power supply pcb, I want to make on for personal use - Page 5 - diyAudio
Old 6th January 2014, 02:06 PM   #41
Trileru is offline Trileru  Romania
I just wanted to set it at about 40-50mA for good measure. Can always be left out if case...
I appreciate your ideas thou, not much feedback on this and being my first ever PCB I like feedback
Old 6th January 2014, 10:59 PM   #42
Someone told me how to remove the layers from the heatsink and now I can do a full ground plane. I also made a 3d rendering of the board so I have an idea on how it will look like. Pretty neat!
I will probably get some tantalum capacitors on the ADJ and output but for the test it's nice.
Old 8th January 2014, 04:49 AM   #43
It is advisable to drill holes on the pcb, near the periphery of the heatsink.
Gajanan Phadte
Old 8th January 2014, 08:06 AM   #44
Gajanan Phadte
I don't understand. You mean the securing holes? I guess that at the board's size that wouldn't matter as it's pretty stiff and the weight on it is not that much but I guess I could try to fit an extra one near the heatsink somewhere.
Old 8th January 2014, 09:25 AM   #45
No, these will allow air passage over the heat sink from beneath the pcb.
Gajanan Phadte
Old 8th January 2014, 10:21 AM   #46
Oh, that's good! Haven't thought of that!
I will do it. Any ideas on how many and what size...in general?
Old 8th January 2014, 08:15 PM   #47
00940 is offline 00940  Belgium
A few comments:
- Think in terms of power planes. There's no reason your positive power traces should be so much smaller than the ground traces.
- There's an optimal way to connect r1 and r2 for optimal performance: r1 should be connected as close as possible to the output pin of the reg, not sharing the output track (or as little as possible) and the ground side of r2/c5 should not be tied to the power groundplane but by a dedicated track directly to the gnd ouput terminal.
Ben.
Old 9th January 2014, 03:59 AM   #48
4-6 holes on each side of about 3-4 mm diameter should be fine.
Gajanan Phadte
Old 10th January 2014, 09:25 AM   #49
yd1cvj is offline yd1cvj  Indonesia
Hi Trileru,
I found from web also regulated with LT1083.
What is your main reason use LM338 ?
Old 10th January 2014, 09:30 AM   #50
Originally Posted by 00940 View Post
A few comments:
You mean like this?
lm338 regulated power supply bego2 Power Supplies 7 11th October 2012 01:34 PM
Using LM338 and LM337 for 250VA supply camus Power Supplies 2 10th February 2012 04:26 PM
Regulated PSU PCB available for LM338? jmillerdoc Chip Amps 1 3rd March 2011 03:30 AM
Does this power supply make any sense to you? Cassiel Tubes / Valves 14 17th June 2009 05:18 PM
PCB: LM338 Regulated Snubberized PSU yusuf Power Supplies 7 27th March 2007 01:45 PM
Copyright ©1999-2017 diyAudio
