No sound output Peavey Rage - diyAudio
Old 28th December 2013, 03:43 AM   #1
Default No sound output Peavey Rage
Hello this is my first time on the forum and I hope that this is a suitable area to post. I am wondering if anyone can offer me some advice. I have a Peavey Rage 12 Watt practice amp that suddenly lost all sound output. From my extremely limited electronics diagnostic knowledge, I donít think that it is a power supply issue because the power light is on and I can hear a static sound from the speaker. Not a very technically sound diagnosis but hey I have to work with what Iíve got I have read that TDA2040 power amp chip failure is quite common and as these are only a couple of dollars am wondering how I might test this IC in my amp to see if it is the problem. I have downloaded a circuit schematic and have a multimeter and a ton of enthusiasm so how might I proceed.
Thanks for reading this and hopefully offering some advice Pedro.
Old 3rd January 2014, 03:12 AM   #2
Hi sonyzz!! The way i take over this things is : with VOM check PS then trace signal and locate failed components! But First...
relate your circuit to the schematic, follow traces, check visually, smell...
then check ps etc.you might have blown resistors or caps. check res with meter
have good luck and take breaks!!
Old 3rd January 2014, 05:56 AM   #3
Click the image to open in full size.Thanks for replying Martin, and also for the tips in helping to diagnose problems. What I did find was a loose PCB mounted input socket
Peavey CS-800 output subs? redrooster Instruments and Amps 11 1st February 2013 01:09 AM
Help me bring back to life an old peavey rage 108 guitar amp! delcarmen Chip Amps 17 20th January 2013 04:43 PM
help with cs800 peavey getting 6 volts on output goldfingerxus Instruments and Amps 12 26th December 2011 03:24 AM
Peavey Valveking 100- static sound during warm-up Rotus623 Instruments and Amps 80 6th December 2010 03:16 PM
Hifi frustrations / rage /destruction ash_dac The Lounge 0 7th March 2006 07:22 PM
Copyright ©1999-2017 diyAudio
