Old 25th December 2003, 01:21 PM   #1
Default Tda 7386 Spice Data Required
I just purchased a couple of TDA 7386 , 4 channel 45 watts each in Flexiwatt 25 package, I wanted to build a 5.1 channel amplifier however to my disappointment Circuit Maker 2000 does not have pakcage for such amplifier, can anyone help by providing SPICE DATA for Flexiwatt 25 package???????
Old 28th December 2003, 06:28 AM   #2
Default RE: Help Wanted Desperately
Does any one in this wide world knows the answer to my querry even the moderatrs please???????????????????????????????????????????? ??????????
Old 28th December 2003, 07:14 AM   #3
pieris is offline pieris  United States
A link to the TDA7386 on the ST website will do simulation for you, hope that helps.
Old 3rd January 2004, 02:28 PM   #4
Default Re:
I ma highly obliged, let me look at ST website and I ll be back.
Old 10th January 2004, 03:05 PM   #5
Default RE
"PIERIS" Thanks man for your tip however, unforunately, mentioned link provides simulation only it does not provide SPICE DATA so that it could be used with circuit maker 2000 and a PCB could be designed, then again "THANXSSSSSS"
Old 11th January 2004, 09:38 AM   #6
Default RE:
Well let me put my request and correct it slightly, i.e I need the macro module for the concerned IC, in the form of a device library which could be used both in Circuit maker and Trax maker, any help in this matter would be welcome????
Old 25th January 2004, 05:00 PM   #7
Does anyone in this world could help me to guide how to define TDA7386 in circuit maker 2000 and probably then import the same in Traxmaker 2000
Rehan
Some DIY Projects
Old 1st February 2004, 05:39 PM   #8
Default TDA 7386: CHIP SOUNDS ASTOUNDINGLY WELL
Well, if someone may be intersted I printed about 400 pages of manual of traxmaker and found a way to make footprints of the chips, PCB was then no problem, believe me guys once i put it in use this chips sounds incredible, very low THD good output and good heat disspiation, All the trouble making PCB of the Chips is well worth it. besides a chips worth 6$ sounds good for its price.
Old 2nd May 2007, 12:15 AM   #9
hey abid_rehan hi, by coincidence you have the PCB of the Tda7386 that you armed?, please you can sent it me?, or post here, thanks
Old 3rd May 2007, 08:25 AM   #10
Its been a while since I used these chips, let me go through my old files and see if i could find layouts for 7386, but that time I used circuit maker 2000.
Let me see if i could find it.
If its there I ll definitely post it here.
TDA 7386 Help Please supersonik Chip Amps 5 3rd August 2009 07:54 AM
Free Spice Or Cheap Spice Simulator-Where To Start? kelticwizard Everything Else 29 15th February 2007 02:38 AM
Help required ! LarryN Parts 2 19th July 2004 02:05 AM
Spice data for penultimate zen Rixsta Pass Labs 1 28th April 2004 10:36 PM
Page generated in 0.35008 seconds (25.70% PHP - 74.30% MySQL) with 10 queries
