| Chip Amps Amplifiers based on integrated circuits |
I’m about to buy parts for my first two electronics projects -
Two P2P ‘gainclone’ amps, based on the LM 3886 & TDA 7293 datasheets I’m going to prototype the two amps, with interchangeable power supplies, before replicating in a three-way part dipole active. (I know a guy doing the LM3875, and we’re going to compare, but I don’t want to burden him with more newbie questions). Some parts (eg feedback resistors) I have answers for or worked out. But others, when I look in the array of catalogues of vendors (I found through searching for recommendations here), and read the odd electronics 101article, I have almost no idea of the difference *in appropriate application* for: axial/ electrolytic/ bipolar/ nonpolar polypropylene/ surface mount etc: - So for the components below – which is best?? *Please suggest* the best type of components, and a lesser priority also brands, for these : LM 3886 (Non-inverting, per the datasheet) resistors: Inverting input resistance (Ri) preventing current entering non-inverting input (Rb) frequencies to short out R & pass signals to the load (Rl) TDA 7293 R1 Input resistor R2 & R3 Closed lop gain R4 ST-by time constant R5 Mute C1 Input DC coupling C2 Feedback DC coupling C3 Mute time constant C4 ST-by time constant C5 Bootstrapping C6-9 Supply voltage bypass On another note: I went to Digikey to look at Panasonic FC; usually I found minimum order quantities of 10. Any suggested suppliers for good mid-range parts with no MOQ?? Your advice is appreciated! Happy Christmas Richard |
#2 |
I don’t mind if you state the obvious – please help:
(Apart from eg Vishay/ Caddock from eg Percy Audio for feedback resistors) - what sort (eg bipolar? axial? Thanks Newbie |
| tda 7293 and tda 7294 help | sagarverma | Chip Amps | 82 | 6th November 2011 06:20 PM |
| TDA 7293 parallel problem ! | Cro maniac | Chip Amps | 5 | 4th May 2010 02:57 PM |
| Power Amp IC TDA 7293 | headsavers | Parts | 2 | 22nd September 2006 02:39 AM |
| Impressions of Snubbered BrianGT 3886 vs Reg 3886 | moving_electron | Chip Amps | 1 | 23rd March 2005 07:51 AM |
| PA Amp with TDA 7293...Questions... | iCebReakEr409 | Solid State | 5 | 8th August 2002 09:59 PM |
| Page generated in 0.07685 seconds (67.91% PHP - 32.09% MySQL) with 10 queries |
