LM3886 Chipamp Project
Old 26th November 2013, 08:38 PM   #1
261jack is offline 261jack  United States
Default LM3886 Chipamp Project
I am new to this website and the chipamp project world - I am interested in building an amp based on the LM3886T [uninsulated] and have been researching the project on the internet [this site has been very helpful in my research] - I have two questions; #1: Using a hefty power supply, can a transformer with one secondary suffice for both chips? - #2: if fully insulated, can one large heak sink be used for both chips [I understand that the chip's tab is at the same potential as either the + or - supply voltage] - thanks, 261jack
Last edited by 261jack; 26th November 2013 at 10:04 PM. Reason: questions better phrased
Old 27th November 2013, 03:38 AM   #2
djoffe is offline djoffe  United States
Take a look at the approach in the GT-101. I think it will answer a lot of your questions.
Akitika GT-101 Audio Power Amplifier Kit
The manual has schematics and wiring instructions...that might help with a lot of the other questions:
http://akitika.com/documents/Assembl...101rev1p37.pdf
Old 27th November 2013, 07:11 AM   #3
availlyrics is offline availlyrics  India
availlyrics's Avatar
" #1: Using a hefty power supply, can a transformer with one secondary suffice for both chips?"
Yes
"#2: if fully insulated, can one large heak sink be used for both chips [I understand that the chip's tab is at the same potential as either the + or - supply voltage]"
Yes, one large heak sink be used for both chips. A small fan would also help keep things cool.
BTW the tab is -ve .
Thanks,
availlyrics
Old 27th November 2013, 11:52 AM   #4
MrBlc is offline MrBlc  Croatia
For uninsulated version, you should use insulation pad and insulation ring. With insulation pad and ring, one large heak sink be used for both chips.
You don't want to have heatsink on -Ve. It's security risk (you could make short circuit) and it could induce any noise from negative rail to the components conected to input or feedback. As result, amplified noise could appear on output or, in worst case scenario, amplifier could oscilate and burn itself and/or speaker.
Old 28th November 2013, 12:05 PM   #5
THANKS TO ALL FOR U'R ANSWERS - JUST SEARCHING FOR DESIGN SIMPLICITY [FEWER PARTS] AND AS MUCH HEAT TRANSFER AS POSSIBLE - I KNOW AUDIOPHILES WOULD NOT LIKE MY IDEA - HAVE A GREAT THANKSGIVING OR DAY - 261JACK
Old 28th November 2013, 01:13 PM   #6
overtheairbroadcast is offline overtheairbroadcast  Canada
Another satisfied customer.
Anyway, for me, just reading your replies I am a little more educated. But to extend the question regarding power supplies... I usually use a switchmode power supply for the few chipamp I have made. Is there any advantage in using big iron from Hammond or Edcor and rectifying it instead versus the Meanwell SMPS I have been using?
Or is it more preference?
Old 28th November 2013, 01:18 PM   #7
A single supply circuit with a big speaker coupling cap gives you the best possible thermal outcome. The negative rail of the pair is then ground, and you can bolt the uninsulated part directly to the heatsink. The heatsink attaches to the chassis. That minimizes the overall thermal resistance. That's what's done in the GT-101.
LM3886 Chipamp ProjectHide this!Advertise here!
LM3886 Chipamp Project Resurrected slomatt Chip Amps 26 18th September 2013 11:10 AM
chipamp lm3886 help dnic77 Chip Amps 5 13th May 2013 07:05 AM
Chipamp Lm3886 project, need help... Geoffroy Chip Amps 17 23rd October 2009 10:02 AM
LM3886 chipamp project to start in a while shoq Chip Amps 2 24th March 2009 08:03 AM
