Replacement for OPA2134 at DC Servo - diyAudio
Old 2nd November 2013, 12:57 PM   #1
Default Replacement for OPA2134 at DC Servo
I would like to ask your opinion in replacing OPA2134 for an LME49720 in one DC Servo application?
Technically wich one should do a better job?
Thanks for the help
Old 2nd November 2013, 01:36 PM   #2
See attached schematics of the application if needed.
I did replaced the opamp at the servo location with the lme.
Just to want to ensure that changed for a better one for the specific purpose.
Old 2nd November 2013, 02:49 PM   #3
Why would you put a 2134 in a servo application? A servo op amp should be optimized for DC operation. A 2134 is a favored amp for audio application.
Apples and oranges.
Since you replaced it, did you measure offset and drift before and after? That way you could answer your own question.
Old 2nd November 2013, 02:57 PM   #4
Mooly's Avatar
The OPA should be the better of the two due to being FET input as you need minimal input bias currents. A TL071 is often the usual choice.
Installing and using LTspice IV. From beginner to advanced.
Old 2nd November 2013, 03:00 PM   #5
Hi, and you don't need anything "better" than a TL071 or similar, rgds, sreten.
However the circuit appears to use dual op-amps, so the question is very misleading.
Old 2nd November 2013, 03:03 PM   #6
Fast Eddie: it was already there, as its a branded product that I was trying to improve.
I dont have that much knowledge and Im trying to understand.
Moly: should the TL071 outperform the 2134 in there?
Old 2nd November 2013, 03:11 PM   #7
DUG is offline DUG  Canada
How much offset will you allow?
According their respective data sheets:
Vio
OPA2134 +/- 2mV max
LME49720 +/- 0.7mV max
TL071 +/- 6mV max
That does not mean that they will be that much but it is what I would start looking at.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 2nd November 2013, 03:46 PM   #8
Mooly's Avatar
The OPA should be fine as servo chip. No real difference between that and a TL071 for this application. You don't all the attributes that make a "good" audio chip. You need low input bias current which means FET input.
Old 2nd November 2013, 03:55 PM   #9
Mooly's Avatar
Vio
OPA2134 +/- 2mV max
TL071 +/- 6mV max
Look at the input bias current for the LME49720. I think its 10 nano amp. Sounds small until you realise it would deliver a 100mv offset with a 10meg resistor at its input. The OPA with 5pa bias current would deliver 0.05 mv under the same condition. The TL071 would be a similar ballpark figure.
Old 2nd November 2013, 06:30 PM   #10
00940 is offline 00940  Belgium
+1
From the schematic linked, it seems like the same dual opamp is used both as output buffer and servo. So we need an opamp able to fulfill both roles.
OPA2134 seems perfectly fine here.
Ben.
To use DC servo or not? jaycee Solid State 42 8th December 2014 09:19 AM
OPA2134 replacement soulreaver1 Parts 7 25th July 2012 04:03 PM
DC blocking cap in feedback path or DC servo? roender Solid State 27 19th September 2007 10:40 AM
Preamp - Massive DC Offset (OPA2134) DrSplodge Chip Amps 21 11th January 2004 12:49 AM
Copyright ©1999-2017 diyAudio
