| Chip Amps Amplifiers based on integrated circuits |
Hi. everyone. I'm new here. I have a problem with an Trace Elliot SuperTramp twin stereo chorus, guitar amp, blowing / exploding
the TDA 1514A chips. I cant get any Tech support, schematic's or such. these blow after jaming hard for 20min's or so, at a vol.. of 6 to 8. think the heatsinks maybe to small,? a bad designed output modual,? any id? Power Tran is 25 0 25 at 1.1amp RMS is 2x40, 2x55 peak at 4ohm's. Would even like to mod the output's if some on here could give me some dirrection to go. This amp was made back in july of 1995 if any one has schem's T.Lelliot made differant ver. of these amp's with out the TDA 1514A. Thanks Glad I found this place, have some other project's I mite get off the ground now. |
#2 |
Banned
On the TDA1514A datasheet:
Supply voltage range: +/- 10v to +/- 30v. Your transformer (25-0-25): After bridge and caps (25+1.414) = +/- 35.35v BAAAAANG!!!! |
#3 |
datasheets, calculators and DVOMs.
ron |
#4 | |
(just so RIC understands you better). Guilherme. |
#5 |
So I take it Trace Elliot has a bad design? the power supply to the preamp / FX . come's off the TDA 1514A board, and shows,+35 -35, and ground, mute and signal of course.
what would be a good fix. |
#6 |
Unless there is some sort of voltage reg in the power lead path.Exam LM317 and LM337?
ron |
#7 |
Or just use 2 12V batteries for P/S , it gives you +/- 12Vdc and provides for a much much cleaner signal.
ron |
#8 |
As in car batteries? ha.. Their's are no voltage reg's.
just trans-bridge-caps, ect... This amp was manufacture in july of 95, think thay mite of learn something over the years? |
#9 | |
diyAudio Moderator Emeritus
The question is if RIC wants a cleaner signal for his guitar amp ! +/- 35 V is too much for the 1514, maybe you can hack in a pair of LM3875 ?? BTW isn't it *might* instead of *mite* ?? Just to know if I learnt english the right way....
It's only audio |
#10 |
Very true, i keep thinking audio not guitar.Yea gotta have that ragged sound.
ron |
| C-Audio SR404 hand holding for diagnosis requested | boomi | Solid State | 0 | 3rd July 2009 02:53 PM |
| New Pass Integrated? Nelson holding out on us? | lgreen | Pass Labs | 50 | 4th April 2008 08:14 PM |
| Soldering and holding Large wires ! | wytco0 | Parts | 7 | 2nd November 2004 05:23 PM |
| could John Audio re-desigh the Trace elliot TDA 1514A layout | RIC | Chip Amps | 1 | 27th December 2003 05:39 PM |
| Page generated in 0.09688 seconds (77.86% PHP - 22.14% MySQL) with 10 queries |
