| Chip Amps Amplifiers based on integrated circuits |
Morning all,
Please allow a long time lurker of the diyAudio treasures a simple question. This could be solid state, but since I'm doing a GC I thought I'd ask here......... Wondering about your preferred wire for 2 purposes: 1) In P2P work when the leads are not long enough (shorter is better I know, but.....) 2) Type and configuration of wire for carrying signal from input on rear panel to the 'engine' (twisted, shielded, bare, silver, tinned copper ......) I realise that thickness (AWG) has to be suitable for the loads carried in supply/output lines so my question is more in terms of materials (copper, silver, tinned copper....), isolation (PFTE, none.....) and configuration (twisted, shielded, single......) Thanks Henrik
Regards, Henrik Juhl |
#2 |
Merry X-mas to all
Judging from the number of bidders to my original question I have one additional: OK so you gues are all running wireless..... How did you do that? (Only now do I realise the full meaning of 'less is more' Geez I did not realise wireless applications had come this far, perhaps I need to do some studying.... Henrik
#3 |
Henrik,
1. Doing P2P you normally use the existing leads of the parts and you don’t need any additional wires. 2. I don’t see if there could be any special rules for the internal wiring of the GC. Use the wires you like anyway. Merry Christmas to you too. Pedja |
#4 |
I like bare copper, solid core, ga.19 or less ( 0.5mm would be fine). If you have good sounding silver wire, you might try it too.
I use 18ga for PS wiring.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#5 |
24 ga on internal wiring,18 ga on P/S all solid Cu. Try not to use any internal but with a selector switch its necessary.
ron |
#6 |
It is the copper (if it is the copper, I don’t have an experience with pure silver) that matters. The best wire I tried till now as signal wire was 0.34mm^2 but it is likely that certain variation from this will also work. For supply I use 1.5mm^2 (same for the power cord). All solid core, of course. While it is often good to put a few solid core wires in parallel, the stranded cables usually don’t sound natural.
Pedja |
| Internal wiring | ceebmoj | Chip Amps | 8 | 23rd January 2008 11:01 PM |
| dac internal wiring | sparkle | Digital Source | 16 | 8th May 2005 11:52 AM |
| Recommendations for Internal Signal Wiring | Killjoy99 | Solid State | 17 | 15th October 2004 09:57 AM |
| Internal wiring? | Mayday | Multi-Way | 22 | 5th March 2004 10:54 PM |
| Internal wiring | 2Bak | Parts | 5 | 29th July 2002 10:37 PM |
| Page generated in 0.09218 seconds (74.60% PHP - 25.40% MySQL) with 10 queries |
