Need help with my LME 48930 amp - diyAudio
Old 13th October 2013, 08:40 PM   #1
fiscal is offline fiscal  France
Default Need help with my LME 48930 amp
Hi
I have a hum with my new LME 48930 amp. It is a 2 x 100 W (8ohms), with two pairs of 2SK1058/2SJ 102 mosfets. There is a single power supply +/50 V, ClC one, with 2 larges 22 mH capacitors, and 1,8mh self on each rail.
I don't understand why I have this hum, with the IN+ connected to ground.
Here's a capture of th e mesure with cold amp (5mv/2ms)
and the same (each chanel) 15 mn later (hot amp)
I try lots of thing: add big electrolytics caps, change value of bias cap, change the bias courant (130 mA on each mosfet), and no effect.
Here's the schema and the PCB. Can you help me?
(there is a offset control)
Thanks!
Georges (sorry for my bad English)
Old 14th October 2013, 12:03 AM   #2
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
You could be seeing the cap charging currents imposed on a non-zero ground impedance. To see if this is so, please show the wiring of the main 22mF rail caps and how these connect to your PCB?
The only thing I can see potentially wrong in your grounding on the PCB is that you're using a noisy AGND to feed the mute pin - you could try moving this to a quiet ground (from the star). Oh and C14 also should go to the star, not to a noisy AGND. And R5 needs its own quiet ground, since the one it currently has is polluted by the noise current through C11.
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Old 14th October 2013, 08:52 AM   #3
Originally Posted by abraxalito View Post
You could be seeing the cap charging currents imposed on a non-zero ground impedance. .
This is very likely.
Bad Grounding and particularly sharing a charging circuit with an audio circuit trace or wire.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 14th October 2013, 08:51 PM   #4
Thank you for your answer
There is the schema, the PCB and two photos of the power supply with the amplifiers:
There is an flip flop and a soft start on the power supply you can't see on the schema.
The star ground is the five pins near the two bridges rectifier: two pins for amplifier's ground,, two for the HP's an one for the in signal.
The AGND is connected to the earth by a 100 R/100 nF.
For the mute, I try to change with a 5,1 V zener diode and the good value resistor to have 160 A: no effect. I try an another power supply: it's worse!
May be a problem with the inductor just above the ground wire on PCB?
Georges
Old 14th October 2013, 10:02 PM   #5
abraxalito's Avatar
Thanks for providing the PCB layout for your PSU. Its clear from this that your 'star ground' isn't one in reality - that's because you have very large capacitor charging currents flowing through it (left to right) and so the tastons to the left will be at a different potential to those to the right.
A star ground really does mean a literal star - all connections to it must meet at an infinitesmally-sized point so that there are no ground impedances in common.
Old 15th October 2013, 08:28 AM   #6
I don't know where you got that PSU PCB from, but in my opinion it belongs in the bin.
You would get better performance hardwiring instead and omitting many of the components that you have included.
regards Andrew T.
Old 15th October 2013, 09:04 PM   #7
This PSU come from TI Application note AN-1849.
I try something like that to connect the amplifiers ground (with a weding wire): thers's no effect . May be I don't understand something with the "real star ground"
Do you think I have to remove the self (just above the signal ground?)
Thank you!
Old 15th October 2013, 10:28 PM   #8
WSJ is offline WSJ  United States
WSJ's Avatar
The amplifier open loop gain is 120 dB (1,000,000) minimum. Any signal on the traces connected to pin 5 (- input) will be amplified 1,000,000 times. The long trace on pin 5 is an antenna. Both gain resistors should be connected to pin 5 with the shortest possible trace. This could be accomplished with a trace length of 0.25 or less.
Old 15th October 2013, 11:37 PM   #9
WSJ's Avatar
Both gain resistors should be connected to - input with the shortest possible trace. This is also the case with discrete amps. Parallel traces next to or under the - input trace will capacitive couple unwanted noise or signals. You can verify the sensitivity of the - input by touching it with a test lead or your finger.
Old 16th October 2013, 01:34 AM   #10
Johno is offline Johno  Australia
Johno's Avatar
Fiscal,
The common mode choke (the inductor) is one of the main causes of your problems.
It is very strongly coupling the +ve rail current to the -ve rail and vice-verse - remember that in class AB the rail currents are more or less equal but opposite. Short it out and you will see improvement.
If you add inductors to the DC rails they must not couple.
Passively Battery supplied LME 49710 RIAA amp for MM cartridge eaglebear Analogue Source 1 5th August 2013 12:52 PM
LME 49810 Kit thor61 Chip Amps 4 22nd February 2013 06:21 PM
LME based amp vs Rod Elliott amp benproiii Solid State 5 6th May 2011 01:59 AM
LME 49713 + LME 49600 pre amp klewis Chip Amps 16 4th February 2011 01:15 PM
National LME 49811 satanx Chip Amps 2 8th May 2008 10:29 PM
Copyright 1999-2017 diyAudio
