Old 17th December 2003, 08:57 PM   #1
Default Attenuation and Vol control alternatives...
It seems that the preferred method for varying the volume of amps is to attenuate the incoming signal. Is it also acceptable
to vary the gain of the chip amp using a pot as one of the gain set resistors? Is this really only applicable to chip amps since there is essentially only one gain stage? Any theories/ experimental data on whether or not this method is better or worse?
Thanks,
Mike
Old 17th December 2003, 10:06 PM   #2
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Send a message via Skype™ to Cobra2
The Hi-Fi police will charge you with contemt for the importance of feedback-resistor quality.
And I'm sure they also will come up with more...
Arne K
Ars longa, vita brevis
Old 17th December 2003, 10:30 PM   #3
GregGC is offline GregGC  Canada
First: Correct me if I’m wrong, but I red somewhere that the optimum gain for Power amp is between 22 and 30 (or something like that, 30dB).
Second: How can you get it down to mute if you use the feedback resistor as a volume control? The lowest it’ll go is gain of 1.
Old 18th December 2003, 07:10 AM   #4
Hybrid fourdoor's Avatar
I asked this exact question once, got some various answers. I thought it would be good, because the input impedence would always be the same, and at low volumes you would be lowering the gain, thus overall distortion.
Anyways have a read
My original thread
PCB drilling alternatives nemestra Parts 11 11th April 2008 12:29 AM
RCA alternatives? ftjandra Parts 12 28th June 2004 07:29 PM
Alternatives to CD-PRO 2 Elkaid Digital Source 27 16th March 2003 09:48 PM
Page generated in 0.06913 seconds (69.66% PHP - 30.34% MySQL) with 10 queries
