tda2616 mute
tda2616 mute
Old 8th October 2013, 05:57 PM   #1
00940 is online now 00940  Belgium
00940's Avatar
Default tda2616 mute
I'm laying out a small pcb for a tda2616 (I know Velleman makes a kit for it, but I don't like it) and I stumbled upon a quite basic question... what am I to do with the mute input (pin2) ? I've had a look on multiple schematics and some tie it to ground, some let it floating. A bit confusing.
The datasheet isn't very clear to me but maybe is it just me : TDA2616Q Datasheet pdf - 2 x 12 W hi-fi audio power amplifiers with mute - Philips
Thanks for any help on this.
All that is excessive is insignificant. Talleyrand
Old 8th October 2013, 06:37 PM   #2
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Simply do not connect the Mute pin. Floating works, connecting it to V+ via a 10 kOhm resistor also is OK. When drawn "low" the chip will mute. Can be a nice solution if you leave the amp powered on, using the mute pin will disconnect inputs so less noise and/or unwanted sounds (when not used). You can see it as a kind of standby function then. Power consumption won't change however.
BTW block diagram on page 3 of the data sheet is wrong. The switch in the middle of course switches both channels to mute ! Should be a double switch in the drawing.
It's only audio. Member of the non modular PCB design committee
Old 8th October 2013, 06:56 PM   #3
00940's Avatar
Thank you :-)
Old 12th October 2013, 03:21 PM   #4
00940's Avatar
Here's the finished unit. Fairly basic, powered by an old printer's wallwart (2*10VAC/40VA).
Paired with some speakers coming from a broken Denon mini-system, it sounds pretty decent as an office system.
tda2616 muteHide this!Advertise here!
TDA2616, PGA2311 soundbar noise problem child1 Chip Amps 2 18th January 2013 09:30 AM
Velleman K4003 / TDA2616 - turn on/off pops IG81 Chip Amps 11 30th October 2012 04:59 PM
TDA2616 plans? mikejennens Parts 0 3rd December 2010 11:30 PM
please help - no mute but did mute mod - tda1541 loomis Digital Source 1 14th November 2002 10:54 AM
Power amplifier with TDA2616 macle Solid State 3 1st October 2001 12:46 PM
