| Chip Amps Amplifiers based on integrated circuits |
Hi.
Pulled out some old school switches from an amp. Stamped on some of the switches is "3A - 125/AC" and under this is "JAPAN". Can this type of switch be used as a on/off switch between the wall outlet (120V) and transformer of my GC PSU? I'm using a 2A slow-blow fuse. So I am assuming the fuse will burn before the switch burns, or anything else burns, if something happens to go wrong. Any input would be most appreciated. Thanks. |
#2 |
I can only say that my mains switch is rated 10A at 125VAC. Yours may be a little borderline BUT if it worked on a power amp before it could be OK.
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#3 | |
Account Disabled
that means the switch allows 3amp going through it. at 110v (here in the US), it means 330w at the transformer. at 50% efficiency (for a class b amp), that's good for 150w output. each gainclone is good for about 50w, so your switch can handle at least 3 gainclone at full power at the same time. That's a lot of sound. |
| switch transformer in a B1 | julius_the_cat | Everything Else | 2 | 9th June 2009 09:44 PM |
| Auxiliary Supplies: Top Switch or small transformer? | EnvisionAudio | Power Supplies | 6 | 19th June 2008 04:17 PM |
| M/S outlet (AC) | bibster | Parts | 3 | 24th January 2008 10:47 AM |
| Using 2N3055 and transformer to switch 220volt | jacquesl | Everything Else | 3 | 6th December 2006 04:05 PM |
| NewarkInOne Ebay Outlet | BrianDonegan | Parts | 0 | 28th May 2005 01:23 PM |
| Page generated in 0.08780 seconds (60.43% PHP - 39.57% MySQL) with 10 queries |
