Old 18th December 2003, 01:01 AM   #11
elizard is offline elizard  Canada
Send a message via MSN to elizard
Originally posted by Peter Daniel
What I can't believe, is that you still didn't finish your GC
Oh no, you misunderstood. I got it playin right after you sent me the chips LONG time ago. And its playin right now too, and what a wonderful sound it is (first time listening to alan parson's project .. interesting i'd say)
BUT its not finished as in i'm still in the need of a good enclosure!
I think I'll ask my gf's dad to make one for me out of sheet metal when he gets a chance (he has all the equipment & metal needed). Either that or I'll get someone to cut the wood for me (sadly living in an apartment is a little hard when it comes to bigger tools)
Old 18th December 2003, 01:03 AM   #12
Originally posted by cowanrg
what im doing for my alephs is adding a second power supply that will run the lighting for the meter (see avatar). this will not run through an on/off, but rather it will be a kind of voltage sense (relay) from the amp. so when the amp turns on, it triggers the relay to turn on the lights. if the amp isnt getting power, the relay wont click on, and no lights...
you can find transformers for an led CHEAP if you have a good surplus place around. maybe a buck or two.
hmm, never thought of a current sensing relay ..
i've 2 old small EI transformers i could use, but I'm not sure if that'd introduce other sorts of noise into the rest of the circuit (unless it was a little farther away)
One thing I noticed is that I need better interconnects (el-cheapos in use now). They're REALLY succeptible to noise from power lines (power cords running close to the interconnects by the pre-amp)
Different pre amp idea bartek Solid State 3 25th March 2008 03:42 PM
I really have no idea what I'm doing here... d to the g Multi-Way 10 7th March 2008 06:04 PM
P.S idea noyan Power Supplies 15 19th December 2007 08:50 PM
An idea! Fully balanced TDA1541A DAC idea. Please comment! cartman Digital Source 8 17th July 2007 08:18 AM
Just an idea bob123 Subwoofers 4 9th April 2006 02:28 PM
Page generated in 0.07478 seconds (72.35% PHP - 27.65% MySQL) with 10 queries
