Help Needed on DIY LM3886 based 5.1 Channel AMP for PC Home Theater - Page 2 - diyAudio
Old 25th September 2013, 04:03 AM   #11
Thanks a lot friends for your valuable suggestions.
I will not use the PSU I got, but will be making a different PSU once I get the transformers.
Will post the further updates soon.
Old 25th September 2013, 04:50 AM   #12
Mihkus is offline Mihkus  Estonia
Mihkus's Avatar
I found SAMWHA caps being pretty good...
What i mean is the price 3$ per 22000uf... You would need 4 of them only..
But thats just for the 5 LM3886 amps.
Old 25th September 2013, 11:31 AM   #13
Collected more stuff:
Wiring kit for soldering/connecting, audio input output ports, PSU components, one transformer:
2 X 10000uf, 63V
2 X 0.1 uf, 100V
1 X 35A bridge rectifier
24-0-24, 5A transformer to power 5X LM3886 boards:
Old 26th September 2013, 04:30 AM   #14
rakesh_sharma23's Avatar
Now for PSU follow this design... Dont forget to attach fuses (Slow blow fuses).
http://www.circuitstoday.com/wp-cont...wer-supply.jpg
Old 26th September 2013, 05:15 AM   #15
Right now I don't have fuses so can I skip this state till I complete the testing and later I can add the fuses when I am finalising the product. BTW what rating/spec fuses I need?
Vendor's site suggests to connect a 60W bulb in between while fist time testing which I can use for now.
About the PSU circuit design, I am confused how to connect the 35A bridge rectifier? There are four legs on it, 3 are similar and one is different. Now all four lags it will be connected but not sure which one to connect where?
Rest is not confusing.
Old 26th September 2013, 07:37 AM   #16
May be this will help...If you are still not able to understand..
Than please wait,
First go through electronics basics ones more..Else you may result in burning or Destroying you amp project.. and can even hurt your self..
Old 26th September 2013, 07:41 AM   #17
Thanks, that really helped a lot.
The bridge rectifier I have is the same one like the image you posted. Now I can move forward.
Old 26th September 2013, 07:53 AM   #18
This will help you in wiring.
http://www.diyaudio.com/forums/attac...tazna-sema.jpg
Old 26th September 2013, 08:04 AM   #19
some very good articles here
Power Supply for Power Amplifiers
Old 26th September 2013, 12:05 PM   #20
Thanks.
Most probably my another transformer for the sub (28-0-28, 5A with provision of 18-0-18, .500mA) will also be ready by tomorrow so I will again go to the market to collect it. I have collected PSU components for LM3886 part.
Now I will also need PSU for the SUB AMP and currently I have this PSU: 12-0-12VAC 1A Input, 18-0-18VAC 1A Input, 27-0-27VAC 5A Input, Regulated 12-0-12VDC 1A Output, Regulated 18-0-18VDC 1A Output, 38-0-38VDC 5A Output .
Please suggest what components I need to change in this PSU? What more parts I need to collect from the market?
DIY Case for home theater PC (HTPC) siliconray Siliconray Online Electronics Store 5 15th May 2012 01:34 AM
3 way active speaker system + Subwoofer based on Lm 3886 & 4780 kuldeep Chip Amps 13 19th April 2012 09:33 PM
5.1 Channel Chip Amp/Gainclone for Home Theater Buddie Chip Amps 117 22nd February 2011 01:01 PM
LM 3886 PCB Based On Carlos Fm Schemetic neeraj Chip Amps 64 11th December 2010 08:24 AM
DIY Amp for my Home Theater ccarrigan Solid State 19 25th November 2002 06:58 AM
Copyright 1999-2017 diyAudio
