Most likely it will run out of current, so a good estimation is one half rated power into half the impedance. You'd also want to use the lowest supply voltage possible as the extra voltage only produces extra heat.
While it's not true that it can't handle a 4 ohm load, it will be severely limited in power output. It may even die if not fully protected and you do something dumb with it. You'd be better off with a better match to your load.
Very true. But a safe assumption is that maximum output into 8 ohms is also close to current limit. It's probably a bit more, but short of measuring it, we don't know.as long as one don't know the current limit, this will all be guessing.
Yes. Just take a course in electronics.Can you substantiate how it will handle a 4 Ohm load ?
I'm pretty sure I already said that before you made your remark about me needing to substantiate my claim.If the output devices are running at maximum current iaw with the datasheet then the maximum power will be halved.
- Chip Amps
- How many watts can the STK4221II IC output at 4 ohms?
