Old 14th December 2003, 11:07 PM   #1
just another
wintermute's Avatar
Question question on rolloff below 100Hz
I made a kit soundcard preamp, initially to allow me to do basic cro measurments with my pc. I'm now thinking I'll also use it with speaker workshop, as a safegaurd between the amp and my soundcard.
I measured it's freq response using rmaa 5.2 and it starts to rolloff at about 150Hz and is down about 1db at 30Hz.
http://home.exetel.com.au/wintermute...mp_compare.htm is a comarison between the soundcard in loopback and with the preamp in circuit.
I don't think I can post the circuit diagram, due to copyright but Its using a TL074 and the only cap in the signal path is a 10nf coupling cap on the input, I suspect this is the culprit, but I'm only guessing, so thought I would ask if I should increase the value of this cap, and if so what to?
Tony.
Any intelligence I may appear to have is purely artificial
Some of my photos
Last edited by wintermute; 16th July 2011 at 12:56 AM. Reason: updated url to new host.
Old 15th December 2003, 04:57 PM   #2
47nF to 100nF sounds reasonable to me.
sreten.
Old 15th December 2003, 10:57 PM   #3
just another
wintermute's Avatar
Thanks Sreten I'll give it a try
Tony.
Some of my photos
Old 16th December 2003, 03:49 AM   #4
just another
wintermute's Avatar
Thumbs up Thanks Sreten
I put in a 68nf wima cap (replacing the no brand 10nf) and not only is the freq response now almost identical to what I get doing a loopback test on the soundcard, but the distortion went right down to almost nothing.
I'll put the new graphs up just as soon as my ISP's web server comes back online
It might get slightly better if I put the 100nF caps I bought at the same time, but they are no brand, and I really can't complain about the freq response improvement the 68nF ones made!!! So I think I'll leave it as is. The only thing that bugs me now is the huge spike at 50Hz with the SC preamp. Not sure where that is coming from since it's running off a 12V battery. probably radiated, the kit came with a cheap plastic box, may be necessary to stick it in a metal box.
OK ISP is back on line new url is http://home.exetel.com.au/wintermute...mpare_MKII.htm
Tony.
Some of my photos
Last edited by wintermute; 16th July 2011 at 12:58 AM. Reason: update url to new host.
Old 16th December 2003, 04:23 AM   #5
Distortion across capacitors is related to the AC drop across
them (higher=higher) and their voltage rating (higher=lower).
but you seem to be sorted /sreten.
Using SS to augment < 100Hz? bigwill Tubes / Valves 3 25th January 2009 06:13 PM
Which Driver to use for 100hz-500hz? KCCT82 Multi-Way 27 6th January 2008 04:59 PM
How to kill a 100Hz open baffle resonance? Katapum Full Range 12 22nd November 2005 04:51 PM
subwoofer/woofer to go up to 80-100hz? Guijs Subwoofers 2 24th October 2005 09:23 PM
Aleph 5 100Hz problem piewie Pass Labs 14 7th April 2004 02:43 PM
Page generated in 0.15629 seconds (41.07% PHP - 58.93% MySQL) with 10 queries
