Elektor Q-Watt project
Old 14th June 2014, 06:54 AM   #21
palstanturhin is offline palstanturhin  Finland
palstanturhin's Avatar
Excellent!
Congratulations!
Old 15th September 2015, 08:16 PM   #22
greenm01 is offline greenm01  United States
Default Speaker Protection
Originally Posted by eskwadrat View Post
I finally received long waiting enclosure
How did this project turn out? Where did you have that custom enclosure designed and fabricated?
I notice that the Q-Watt has speaker protection designed directly onto the amp PCB. Why is that most speaker protection schemes are placed on a separate board?
Old 15th September 2015, 08:36 PM   #23
rsavas is offline rsavas  Canada
Yeah the costs do add up rather quickly. That case looks really nice.
One reason is cost, due to duplication of parts like ac fail opto, bjts etc.
I did notice one room for improvement on the power supply. You are missing R/C snubbers for the rectifier circuit. Look up quasimodo by Mark Johnson in this forum and he also has a nice ps for chip amps, which could be used for this project.
Old 15th September 2015, 08:44 PM   #24
Wouldn't it cost more to have a separate PCB made just for speaker protection?
From a technical and performance perspective, I wonder what the advantages/disadvantages are of having on-board integrated speaker protection built into the power amp PCB. e.g. is it bad idea to put AC on the power amp board? The measured specs of the Q-amp look pretty good, regardless.
Old 15th September 2015, 08:55 PM   #25
Actually if you add up the pcb area for the circuits in duplication, it will be more, > pcb area = > cost.
Having the speaker relay on the p/a pcb is a good idea, as it saves on wiring. Wire directly to binding posts.
One fault that I saw was as you noticed, that they did bring the secondary ac up to the pcb. It is possible to reduce hum if it was not their, so it is a easy fix, just put the ac fail opto on the rectifier pcb and use the opto open collector output as your a/c fail signal in.
I am building something similar, but using the LME49830 and the Semelab laterals ALF16N(P)16.
Old 15th September 2015, 09:05 PM   #26
Ah, yes. Thanks for pointing that out. Because the Q-Watt PCB is so small to being with, Elektor could get away with integrated speaker protection at relatively low cost.
To me, this is well worth it. Less wiring inside the chassis.
Yes. it might make more sense to put the speaker protection circuitry on the PSU to help reduce hum to the AC line.... Or spread the protection between power amp and PSU.
Old 16th September 2015, 01:03 PM   #27
that is what I am referring to in,
just put the ac fail opto on the rectifier pcb and use the opto-coupler open collector output, as your a/c fail signal in.
This way the ac is not needed on the q-watt pcb.
Old 22nd July 2016, 07:29 PM   #28
delange is offline delange  Belgium
I finally received long waiting enclosure. It looks like $million$ dollars, champagne aluminum front with professionally printed labels and plexiglass window w/artwork for UV meters, looks like hi-end gear from top audio manufacturer. I will be doing final assembly for few weeks now, lot's of fastening prep and work as this is 1st amp of its kind and not everything was designed in Solidworks. Once completed, I will post some pictures. For now just a teaser of what's comin'
~Patience is the key ~
Hi there,
I've been looking at this amp for ages too and finally ordered the kit. Looking at the schematics, it is very easy to use symmetrical inputs. The compete amp is built symmetrically so this should be a nice modification.
I'm toying with the idea of building a custom enclosure that would sit right behind the speakers (dual mono design). The enclosure would look like a "tower" with a huge heat sink at the back. The design is still brewing in my head...
I'm very curious how your project evolved. The pictures are no longer available so I was wondering if you could post new pictures and share some of your experiences with the amp.
Old 15th December 2016, 09:13 PM   #29
calpe is offline calpe  Gibraltar
Default Ellektor Q-Watt amplifier
Based on the recent posts in the Elektor web site, you'll find lots of new posts, ideas etc., well worth a look.
https://www.elektormagazine.com/labs...plifier-110656
The PCB's have been re-released as well as the kits.
Take advantage as the i.c. and power transistors are at the end of their production line.
Old 16th December 2016, 08:54 AM   #30
1543 is offline 1543  Germany
1543's Avatar
Elektor offers Q-WATT Kits for 69,95 € in Crazy Christmas Sale until 19.12 and until stock lasts
Elektor Q-Watt projectHide this!Advertise here!
Edwin 20 watt (Elektor 1970 - May) steph_tsf Solid State 30 18th April 2016 08:23 AM
200- 500 watt Tube Amp project toddbailey Instruments and Amps 211 8th January 2015 06:11 PM
300 watt Hi-fi power amp project. hydrovac Solid State 16 23rd August 2013 08:29 AM
elektor 'valve preamplifier' project fermatsEnigma Elektor 1 8th January 2008 04:41 PM
unknown Elektor project Hardi Elektor 13 30th September 2007 07:19 AM
