PCBs for stereo bridged 3886
Old 13th December 2003, 12:14 AM   #1
soundNERD is offline soundNERD  United States
Default PCBs for stereo bridged 3886
I was wondering if somebody has designed a stereo 220W amplifier using 4 lm3886s and made pcbs for it. If so, could somebody please post the pcb layout.
Thank you for your help, Mike
Old 13th December 2003, 12:23 AM   #2
cm961 is offline cm961  Canada
cm961's Avatar
I designed a PCB for a bridged/paraelle amp but its mono. However, I only have one set of bypassing capacitors. They're located in the middle between the 4 chips. Does anyone know if this is good enough, or should each lm3886 have its own bypassing caps, and if so how big?
Pete
Old 13th December 2003, 12:27 AM   #3
Would you mind posting it if you have it Peter?
Old 14th December 2003, 01:48 AM   #4
cm961's Avatar
Sure no problem.
Included in the zip file are four files. One shows the entire board, all components and tracks. One shows the top layer tracks. One shows the bottom layer tracks. And then I've included the schematic as well.
Cautions.... This is untested. I do plan on building it, but not during exams! Ok, now it only has one set of bypassing capacitors for the four op amps. I have no idea whether this is a bad thing or not. Perhaps with a regulated supply it would be ok, or maybe it's fine anyway. I've tested the circuit in circuitmaker and it seems to work fine there. It's pretty well straight from the application note. If you build it please let me know how it goes so I can make any changes before I build it! hehe.
Ok the file is too big to attach, so I'll go image by image.
Enjoy.
Pete
Old 14th December 2003, 01:52 AM   #5
cm961's Avatar
And here's the bottom layer...
Pete
Old 14th December 2003, 01:54 AM   #6
cm961's Avatar
The top layer....
Old 14th December 2003, 01:57 AM   #7
cm961's Avatar
And the schematic. Note that I scaled these by 50% so that I could post them. I can give you the circuitmaker files if you want them. You can get circuitmaker from ***** or their website.
Pete
Old 14th December 2003, 06:54 AM   #8
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
soundNERD, have you missed Thomas Madsen's PCB?
http://www.diyaudio.com/forums/showt...threadid=19157
My looks like this
http://home8.swipnet.se/~w-80046/hif...0schema_p1.pdf
http://home8.swipnet.se/~w-80046/hif...0layout_cp.pdf
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 55 pcb's in order. 45 paid.
Old 14th December 2003, 01:01 PM   #9
Thanks for all of the responces.
This project has been put off for now, since two people have asked me to build them a headphone amplfiier like the one i built using the lm4881 chip and i am working on my 300W subwoofer using the B/P LM3886's. I figured i would ask now so when I get to it i would have the pcb.
Just wondering, has anybody done what I want to do, using 2 x 2 lm3886 in bridged mode?If so, has anybody designed a pcb just for that?
Thanks for your help, though, Mike
Old 14th December 2003, 01:35 PM   #10
peranders's Avatar
.... you don't seem to have checked Thomas Madsen's pcb...?
PCBs for stereo bridged 3886Hide this!Advertise here!
4780 stereo, parallel, bridged, single sided gmphadte Chip Amps 12 12th March 2007 11:42 AM
damping factor/stereo/bridged herndonb Subwoofers 23 14th February 2007 07:35 PM
LM 3886 bridged costy_ro Chip Amps 40 28th April 2006 12:05 PM
LM 3886 stereo kit for the UK pete.a Chip Amps 3 16th August 2005 02:31 PM
Bridged/Stereo, w or w/o servo, inverting 3886, inverting buffer PCB Alexander Rice Chip Amps 9 27th March 2004 06:53 PM
