Made a 2 speaker shoebox "boombox" want to amplify
Old 27th August 2013, 10:41 PM   #1
Nex4 is offline Nex4
Default Made a 2 speaker shoebox "boombox" want to amplify
I have no experience with wiring,speakers,onhms etc,..but know how to use a multimeter for certain automotive related repairs..
I decided to try and make a 2 speaker stereo, and fit them in my shoebox,..eventually got everything wired to a 3.5mm headphone jack to use with my phone..powered on and works,..but low volume for my taste
The way i wired the speakers was negative to negative from each speaker, with 2 wires from the headphone jack connected to those wires, and each positive of each speaker connected to 2 wires on the headphone jack,..so if i decide to cut off the jack ive got left(-)(+) right(-)(+) to solder onto an amplifier(Did i wire my speakers series parralel,?) (4 wires total on headphone jack)
My question is each speaker is 3 ohms 2 watts max,..what kind of amplifier can i make or buy that will work with these using a 9v/12v battery,..ive got a LM386 DIY , and PAM8403 3 watt dual channel bookmarked...i want to push 1 watt to each speaker and 2.5 ohms on each speaker(sound right?)
If someone could make a wire diagram of my setup with a added amplifier configuration,
im new to this stuff, and decided to start learning
Old 28th August 2013, 12:28 AM   #2
DUG is offline DUG  Canada
Place a divider in the box to separate R from L.
Find a 5 ohm 5watt resistor and place in series with each of the + speaker leads and try a pair of LM386 amps.
Have fun learning.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 28th August 2013, 12:51 AM   #3
tomtt is offline tomtt
tomtt's Avatar
Location: kansas city mo, and on occasion, around the world ...
you're on the right track
Old 28th August 2013, 03:16 PM   #4
Have fun learning.
Whats a divider?
heres my speaker setup in a circuit
Mount the resistor like this? and how would i wire both LM386's?
Old 28th August 2013, 06:08 PM   #5
Mihkus is offline Mihkus  Estonia
Mihkus's Avatar
Id put the drivers in seriers and drive them with any amp...
6 ohms... In series they would be 1,5R that would be a bit too low, therefore
Id get tda2003/2040, and smack the speakers with 10W!
Old 29th August 2013, 09:08 AM   #6
Mihkus's Avatar
Theres no need for any freakin resistor!
The way Id wire this thing it would look like this:
print screen
Then wire it to ur 386, solder both signal wires together and you get mono signal.
2 gnds too..
If you want stereo... Then theres no need anyway. You need 2 speakers but they should be alot further away from eachother.
Old 29th August 2013, 09:44 AM   #7
R.I.P.
I agree with Mik,
there is no point in trying to get stereo from one box.
There is no point in using lower impedance, by paralleling, than necessary.
regards Andrew T.
Old 29th August 2013, 02:04 PM   #8
I've tried mono setup and they crackled for some reason, I went back to stereo and they sound clearer and no crackle,...
Sent from my Nexus 4 using Tapatalk 4
Old 29th August 2013, 03:09 PM   #9
I see since i would wire them in series i equal the 6 ohms of the speakers and decrease watts needed, to get 6 ohms for both..then i can push 4+ watts without getting hot..., if i want stereo through the amp i would wire them in parallel which would defeat/burn the amp? so then i would wire each speaker into 1 lm386 each and tie both amps into 1 switch,1 potentialmeter?
Made a 2 speaker shoebox "boombox" want to amplifyHide this!Advertise here!
Speakers Made by the "Response" Speaker Company are they any good? John Biles Multi-Way 16 1st August 2015 01:14 PM
"Spare Parts" Bluetooth Boombox crossover and design help. brandontw Multi-Way 1 4th January 2013 07:59 PM
Need a 4" Coaxial speaker for Portable Boombox bnhoang228 Car Audio 22 25th November 2011 10:28 PM
"Impossible" circuit which seems to amplify anyway. sixSixSeven Tubes / Valves 52 12th March 2011 02:45 AM
8" stereo ceiling speaker/MP3 boombox nordhaven Multi-Way 3 22nd January 2008 09:18 PM
