ad8641/8642/8643 for preamp ? - diyAudio
Old 23rd August 2013, 11:03 AM   #1
Default ad8641/8642/8643 for preamp ?
As a newbie, I need help for verifying a op amp datasheet.
I need +/-9v low current <0,3ma op amps for (single ended) 0/+18db first stage 5M impedance, a piezo charge mode amplifier, and a buffer. PSU with true ground on it own layer.
Does the ad86x serie (soic only) is ok, compared to a lt135x, or tle206x ?
I've chosen the ad864x based on it low bias input to try to limit the noise of stages loaded with 5M, and on it lower distortion compared to tle206x. Lt135x, bjt op amp, has lower impedance, lower noise and distortion and should be the better choice for the buffer ?
Other suggestion ?
I suppose it would be easy to answer for someone with better audio electronic knowledge...
Thanks for help !
Damien
Running a tube preamp into a solid state preamp? Pckid212 Solid State 5 6th January 2013 10:12 PM
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps Travis Clarke Tubes / Valves 3 16th October 2008 04:52 AM
Guitar Preamp = MIC Preamp = other preamp ,,are they all same? Paswa Instruments and Amps 1 12th March 2008 05:16 PM
twisted pear Preamp/other suggestions for Preamp kit LukeDuke Chip Amps 1 1st February 2008 09:57 PM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 07:32 AM
Copyright 1999-2017 diyAudio
