chipamp PSU LED value - diyAudio
Old 20th August 2013, 05:28 PM   #1
davym is offline davym  Europe
Default chipamp PSU LED value
I'm about to put together a chipamp (Brian GT) LM3886 kit and was wondering if I could connect the LED in my mains power on/off switch to the LED connection point on the PSU board in place of the one which came with the kit.
I don't see why not but thought i'd ask before I went ahead.
Cheers
Davy
Old 20th August 2013, 08:26 PM   #2
Minion is offline Minion  Canada
Im sure you can but first take into consideration what voltage the LED in the power switch needs .....
Most LED's need a resistor in series with the LED , the value of the resistor is determined by the source voltage and current draw and voltage of the LED ..
On your PSU board there is a resistor in series with where the LED goes , this resistor drops the PSU voltage down to about 1.5V as most standard LED's run at 1.5V , the LED in your power switch probably expects 12v DC and has a resistor in series with its LED built in .....
So what you might have to do is adjust the value of the LED resistor on the PSU board or else your LED in the power switch might not light up .....
Cheers
Old 20th August 2013, 08:27 PM   #3
JonSnell Electronic's Avatar
If the LED is totally isolated from every connection on the switch, I would think so.
Please take notice of Minion's wise words!
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 20th August 2013, 09:25 PM   #4
lanchile's Avatar
one way is this: AC-LED
Make it simple...Make it better!
Old 20th August 2013, 09:27 PM   #5
Thanks folks, the switch led is isolated but rated 6v. I've sent an email to chipamp, hopefully they will tell me what value resistor I need for the board, that's if I can do it at all and they reply.
Cheers
Davy
Old 20th August 2013, 09:42 PM   #6
Cheers i'll check that out.
Originally I was going to tap the roughly 30v DC from one rail using a couple of 2W resistors the seller sent me but I came across a picture of a chipamp in which the builder had substituted the led on the board for the one in his switch, cant remember who built that amp but I think i have a copy of the picture.
Old 20th August 2013, 09:42 PM   #7
sofaspud's Avatar
I assume the purpose is to indicate that the PSU is working (well enough to light the LED)? Otherwise the LED connection point on the PSU board could likely be left empty, or stuffed with the LED flush to the board and hidden inside the enclosure. The mains switch LED continues as the power-on indicator.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 20th August 2013, 09:45 PM   #8
Your LED will be happy with between 10 amd 20mAmps, so choose your series resistor dependant on the voltage.
If it is to run from a 30volt rail, 2k7 ˝Watt would be ideal
Old 20th August 2013, 09:53 PM   #9
Cheers Jon, thought the ones he sent were a bit on the large side for 30v.
Above is the build which gave me the idea about substituting the board led for the power switch indicator one. It would be neat if i could do the same thing.
btw my build will be very similar to this using a shielded transformer and the same case except i got them to cut the power socket hole in the middle of the rear panel and i wont be fitting the volume pot.
Old 20th August 2013, 11:17 PM   #10
Hi Jon, can I just confirm that 2k7 would be ok? the led indicator terminal input is 6v.
The supplier sent 2 x 4.6k 2 watt resistors with their legs twisted together giving me a reading of 2.2k, I know they are a bit large in wattage but would they be close enough for 6v?
Cheers
Davy
CRC Chipamp psu 6L6 Chip Amps 16 20th February 2012 04:02 AM
PSU for preamp and chipamp kikikaka Power Supplies 9 23rd December 2011 04:53 PM
LED Pushbutton hookup to chipamp problem JohnnyP00 Chip Amps 8 21st February 2010 09:48 PM
chipamp PSU problem, need help sith Chip Amps 12 3rd March 2006 04:40 PM
LM1875 Chipamp PSU. Metallica Chip Amps 6 3rd February 2006 05:38 PM
Copyright ©1999-2017 diyAudio
