Novice resistor issues with Oatley K281
Old 19th August 2013, 12:21 PM   #1
SGMB is offline SGMB
Default Novice resistor issues with Oatley K281
Hi, I've found this site incredibly helpful many times but I've only just signed up.
Please don't laugh at me but I need help with these resistors in my Oatley K281 kit.
I've put most of them in but the last 3 seem to be a mismatch.
The supplied diagram and PCB both call for these...
8K2
2R2
2W2
...I don't know what a 2W2 is and can't find any info online.
What I have are these...
9K2
1R
2K2
I"m not sure if these are legitimate substitutes or if I need to get some new ones. Will I damage anything if they are wrong?
Interestingly, the resistors in the kits parts list bear little resemblance to the ones supplied or listed on the diagram/PCB.
I'm sorry if this is a stupid question but I'm learning... slowly.
any help would be appreciated. Thanks guys.
Old 19th August 2013, 01:50 PM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
Looking at the parts list for the Oatley K281 there is no mention of these sort of values. I don't know where you got them from.
Have a look at http://secure.oatleyelectronics.com/...roducts_id=838
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 19th August 2013, 08:50 PM   #3
The values are printed on the PCB and also the diagram above the parts list. They can be seen in the link you posted. And you're right, there is no mention of them in the parts list. The parts list does not seem to correspond to the diagram/PCB, or the parts provided.
...Hmm... Odd.
Cheers
Old 19th August 2013, 08:53 PM   #4
The resistors supplied closely match the diagram/PCB except for those last 3, but the parts list only has a few matching resistors.
Old 19th August 2013, 10:43 PM   #5
simon7000 is offline simon7000  United States
1R should be R13 vertically mounted on the lower right corner of the board.
2W2 is shown as a 1/2 Watt resistor but this is not a normal designation, that I know of.
2R2 is a small 1/4 watt resistor and is normally just color coded. It looks like it is in the power supply, but the web doesn't show the schematic. If in the power supply exact value is not really important.
The 9K2 looks more like a mis-pick but should be close enough to 8K2 to work.
Be sure to check each resistor with a meter! Even the ones already mounted.
Old 20th August 2013, 08:46 AM   #6
Cheers for that, I haven't yet soldered anything. It's all just hanging there until I sort this out. Thanks, still a bit confused though.
Novice resistor issues with Oatley K281Hide this!Advertise here!
Oatley K272 DC power options. Bibio Headphone Systems 6 27th May 2013 10:01 PM
Thoughts on Oatley K282 Valve Preamp? Maxwell Smart Tubes / Valves 17 11th December 2011 10:44 AM
Oatley K295-extra space for tubes mill23bay Tubes / Valves 0 4th December 2011 07:45 PM
Identify Missing Capacitor in Oatley Kit andytanguay Parts 21 28th March 2011 03:38 PM
Hi, New member just bought k272a kit from Oatley Jack5 Tubes / Valves 4 22nd February 2011 02:31 PM
