LM3886 grounding details - Page 2 - diyAudio
Old 18th August 2013, 10:09 PM   #11
AndrewT is online now AndrewT  Scotland
post8 diagram is wrong.
The PSU shows two links to MAG.
These two links must go to each other.
Only the right most cap pair (Zero Volts) links to MAG.
The 8 components at the right, 6caps and 2 resistors, probably do nothing to improve the output of the PSU. I suggest you delete all 8.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 18th August 2013, 10:18 PM   #12
I don't like diagrams of posts 9 & 10.
Post9 shows the Zero Volts carrying charging pulses being used as the MAG. No the MAG is NEVER on the PSU Zero Volts.
Post10 shows the power connections split up into 4 single wires. The Zero Volts should be joined and the V+, V- and Zero volts must be close coupled as a power triplet to pass over the MAG on the way to each amp PCB.
Similarly the Signal Grounds are split creating a hum loop as soon as the Source to Amp Interconnects are plugged in.
regards Andrew T.
Old 18th August 2013, 10:20 PM   #13
iggy111 is offline iggy111  Croatia
Originally Posted by aparatusonitus View Post
Ok, so you are using single PSU to power both channels? If that's the case do it like in the images below ;-)
Edit: Take output (speaker) ground for left channel from power ground point at left channel pcb, do the same for right channel.
1. What is that between the reservoir caps in the first image?
2. Why connect speaker return to power gnd, isn't it better to connect it directly to main ground?
3. Could you explain what those antiparallel diodes do exactly?
I see that this way you make use of twisting the V+/V-/Gnd wires going to amp boards, right now I just twist V+/V- together.
Old 19th August 2013, 12:37 AM   #14
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
Originally Posted by iggy111 View Post
which of these are you saying I should do:
1. connect signal gnd to bottom of R2 and then wire to MAG, also give nfb gnd a separate wire to MAG
OR
2. connect signal gnd directly to MAG, and connect bottom of R2 to nfb and then wire to MAG?
Its looking like your 2 is what I am suggesting. In your pic the signal ground is shaped like a letter 'T' - I'm saying cut the top left connection (IN-) to that 'T' and give that IN- node only its dedicated wire to MAG. The other connections to signal gnd to remain as is.
<edit> On your PSU wiring pic, why those particular two wires to MAG? Seems to me you do want two wires but not those, rather you want a wire from the -ve and a wire from the +ve. As it is you have fairly major charging currents (those for the 2nd cap) running through MAG. None too pretty.
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Old 19th August 2013, 01:36 AM   #15
Hmm, I'd have to dig up that post where I first saw those two separate wires, it's somewhere in that huge discussion about PSU quality... but then again, I'm the one usually wrong here so I'll definitely change that.
I can understand removing the 3.3uF, but remove the bypass 100nF and snubbers?! Why? Isn't bypassing large capacitors a proven method, and don't snubbers remove the diode switching noise and help with the psu impedance?
Old 19th August 2013, 09:43 AM   #16
the snubber is in the wrong place.
The bypass increases the quiescent ripple being fed to the quiescent amplifier
regards Andrew T.
Old 19th August 2013, 10:35 AM   #17
I'll test it without the bypasses. Where should I put the snubbers then - before or after the first reservoir caps?
Old 19th August 2013, 10:42 AM   #18
across the transformer tappings right next to the rectifier.
regards Andrew T.
Old 20th August 2013, 06:46 PM   #19
I made some changes to the PSU:
- removed one of the wires going to MAG, connected first reservoir ground to second reservoir ground
- moved the snubbers to the transformer tappings
- removed the 3.3uF caps
- moved the 100nF bypasses directly to the pins of second reservoir caps
Can't say I hear any difference. The slight hum is exactly the same as it was, it is still a bit louder in the left channel (with some very slight buzzing), but that's basicaly irrelevant, can't be heard even at 1m from the speakers.
I still have to try the signal / nfb ground change, and decoupling MAG from chassis ground, so I'll post again.
PS - I have lots of changes going on (P2P, grounding, LDRs, paralleling Simics...) but changing the gain and adding diodes in series with V+ and V- make the greatest positive changes. Here's a link to diodes trick
Old 20th August 2013, 08:51 PM   #20
aparatusonitus's Avatar
It's just a CMC (common mode choke)...in your amp psu you have an RC filter, you can make it a bit better if you place another R (like 0R1/10W in front of first filter capacitor so your PSU become an RCRC filter. Don't put more then 0R1, 'cos there is already dynamic impedance of diode bridge + resistance from transformer secondaries + transformer leakage inductance reactance.
12. Why connect speaker return to power gnd, isn't it better to connect it directly to main ground?
No, in theory at least, all input, feedback and output ground should be referenced to the same point - power ground as close as posible to amp supply pins/decoupling capacitors.
13. Could you explain what those antiparallel diodes do exactly?
It's a ground separator, protecting you from killing yourself and potential ground loops from the rest of you system (house wireing).
Do exactly as I show you before, with lots of wire twisting of equal length for left/right channel, stay away with wireing from transformer, or place wire perpendicular to transformer radius (if it's toroidal), do not parallel line carring high current with signal lines, make them cross if you have to. If you follow this rules, you will not hear any noise or buzzing from your speaker any more.
Non mai abbastanza...
LM3886 kit DC grounding fabricated Chip Amps 12 13th February 2012 06:40 PM
LM3886 Chip Pin 7 Grounding MSM Audio Chip Amps 1 2nd June 2011 05:49 PM
Lm3886 grounding made easy(?) pacoblackxx Chip Amps 34 13th July 2010 02:42 AM
lm3886 grounding made easy(?) pacoblackxx Chip Amps 2 1st July 2010 09:53 PM
Grounding hum on lm3886 kit encode Chip Amps 7 5th May 2008 01:36 AM
Copyright 1999-2017 diyAudio
