Umbilical cord suggestions
Old 10th December 2003, 03:30 PM   #1
Stever is offline Stever  Canada
Default Umbilical cord suggestions
Hi all,
I've been working my way towards putting my breadboard IGC into a final design enclosure (pics soon) and would like to ask for some suggestions on the Umbilical cord between supply and amp.
I will have two power supply housings and one amp box containing both channels. I only need about 1 foot max cord length for each. Envisioning the cords being fixed at supplies with connectors on amp for easy moving.
1. Wire suggestions? Braided seems logical so I'm not worrying about stressing and breaking a solid cable.
2. Connector suggestions? Type and and source would be great!
Anyone using plain 'ol Home Depot appliance/tool replacement cord with the three wires? I'm also very open to wire suggestions from places like Parts ConneXion as well.
Thanks in adavnce,
Steve
Keep your stick on the ice!
Old 10th December 2003, 03:39 PM   #2
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Umbilical cord suggestions Send a message via AIM to Peter Daniel
A practical choice is Kimber Speaker cable (8 wires) and CB radio mike connectors (available from Electrosonic).
http://www.diyaudio.com/forums/attac...&postid=245778
Later I found that this cable sounds a bit flat and laid back and changed for Cardas 20ga. hookup wire. Although more expensive, it's worth the upgarde.
To order kits contact me through forum mail.
Old 10th December 2003, 03:42 PM   #3
officeboy is offline officeboy  United States
Send a message via MSN to officeboy
As for connectors, I've seen a lot of people use these; (from parts express)
090-535 CB MIC PLUG 4 PIN FEMALE $1.65
090-542 CB MIC CHASSIS MOUNT JACK 4 PIN H $2.50
And it's what I've gotten for my first IGC too.
As for wire, I found some nice 16ga 4-wire stuff at Home depot, and it's cheap, cost me $1.20 for 5 ft of it. I'll have 2 grounds and then +/- 25V. Of course mine isn't done yet either, but it's the best I was able to put together based on what Iíve seen here. I know others have used a bunch of single wires, and then sleeved it but that seems like just a bit to much work.
Old 11th December 2003, 12:27 PM   #4
Thank you gentlemen,
Just what I was looking for.
Steve
Old 12th December 2003, 01:16 AM   #5
pjb is offline pjb  United States
Default speakons
The neutrik speakon connectors are great, and you
can get them in 2,4, and 8 pin connectors.
www.partsexpress.com
and they're cheap! compared to XLR's etc.
Old 12th December 2003, 01:36 AM   #6
matjans is offline matjans  Netherlands
matjans's Avatar
Send a message via MSN to matjans
ah yes those speakons are pretty good (and not too expensive) but they're pretty big too. And, most important, not meant for power connections. The Neutrik Powercons are meant for power connections and (thus?) are much more expensive.
Oh well, methinks speakons are good enough for a GC anyways.
Old 12th December 2003, 08:22 AM   #7
Ropie is offline Ropie  United Kingdom
Ropie's Avatar
Speakons are fine for the power connection from psu to amp, they are well within their operating limits there.
Umbilical cord suggestionsHide this!Advertise here!
Separate power supply - Umbilical Cord marcutan Tubes / Valves 39 27th January 2010 07:18 PM
Design of umbilical cord Rafal Chip Amps 16 9th September 2008 01:33 AM
Umbilical Connector Suggestions Bryan Tubes / Valves 14 11th June 2004 05:00 AM
Umbilical cord capacitors, x Bosoz dqswim Pass Labs 0 27th April 2004 11:25 PM
How do you make a power supply umbilical cord?? raincheck Pass Labs 8 16th January 2003 01:14 AM
