Connection of Transformers
Old 9th December 2003, 03:59 PM   #1
Matttcattt is offline Matttcattt  England
Matttcattt's Avatar
Default Connection of Transformers
I have two 18v-0-18v 160VA transformers and i want to connect them together to get 18v-0-18v and 320VA. they both are the same make/model etc. they both have dual secondries. should i use dual bridges?
If it aint broke, don't fix it. If it is broke, fix it.
If you can't fix it, take it apart and see how it "worked".
Old 9th December 2003, 04:30 PM   #2
Matttcattt's Avatar
sorry about the double post, i took to long to edit the first one.
can i just parrallel them like this? (each secondary parralleled to the respective one on the other trasformer)
Old 9th December 2003, 04:52 PM   #3
officeboy is offline officeboy  United States
Send a message via MSN to officeboy
As I understand it, if you hook them up that way there can be some issues with one transformer feeding power into the other at times, You would be better off to hook them up after the rectifiers I think.
Old 9th December 2003, 04:54 PM   #4
GregGC is offline GregGC  Canada
Default Re: Connection of Transformers
I'd use separat bridges and PS caps. One transformer per chanel. Theis way no interference between the chanels and the amps always see 1000.0 uF per rail (If 1000uF is your choice).
Old 9th December 2003, 05:35 PM   #5
Matttcattt's Avatar
Default Re: Re: Connection of Transformers
can i just connect it up after the rectifiers?
my amp will have 6 channels (as posted in another thread).
Old 9th December 2003, 05:45 PM   #6
Vigier is offline Vigier  Netherlands
OK,
then you can attach 3 amplifiers to the first transformer en the other 3 amplifiers to the second transformer. (Just like GregC said, but then 3 amplifiers for each transformer)
I don't know what the other thread is, but
if it's for a 5.1 amplifier:
Transformer 1: Front-Left, Rear-Left, Front-Center
Transformer 2: Front-Right, Rear-Right, Sub
if it's for stereo, but tri-amped:
Transformer 1: all channels for left
Transformer 2: all channels for right.
You could also use Transformer 1 to feed the bass-amplifiers for both speakers, and Transformer 2 for mid & high of both the speakers.
Grtz, Joris
Old 10th December 2003, 08:19 AM   #7
Matttcattt's Avatar
i have already built the amplifier and all the channels' power rails are connectted together. will office boy's suggestion work?
Old 10th December 2003, 08:55 AM   #8
li_gangyi is offline li_gangyi  Singapore
li_gangyi's Avatar
Well yes insjhort it will...however you get better seperation using seperate supplies for ur Amps...
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 10th December 2003, 11:32 AM   #9
Matttcattt's Avatar
ok, ill just connect them after the bridges.
Old 10th December 2003, 11:46 AM   #10
JOE DIRTŪ is offline JOE DIRTŪ  Canada
JOE DIRTŪ's Avatar
matt if I may make a suggestion......connect them after the bridge but place some current limiting resistors in before each bridge.....that way both transformers will only draw their rated load
DIRTŪ
Connection of TransformersHide this!Advertise here!
Help identifying a pair of output transformers and power transformers mjk130 Parts 3 30th January 2009 11:44 AM
CD-ROM - DAC kit connection Tuliman Digital Source 2 6th July 2005 01:36 PM
transformers, regulation, triode-connection... metebalci Tubes / Valves 11 20th February 2004 01:01 PM
AES/EBU Connection fmak Digital Source 2 20th September 2003 12:29 AM
Copyright ©1999-2017 diyAudio
