My BPA200 PCB
My BPA200 PCB
Old 8th December 2003, 08:09 AM   #1
Dxvideo is offline Dxvideo  Turkey
Dxvideo's Avatar
Send a message via Yahoo to Dxvideo
Default My BPA200 PCB
I am working to realise the NSC's reference design BPA200 project for one week. And last saturday+sunday I designed a PCB for it. I don't use the op-amps as your recomendations.
Here is (I can send it by four pieces) the PCB. The first piece is the on board stabilisators, second is the non-inverted parallel unit, third part is inverted parallel unit and the last one is buffer op-amp...
Please make some comments about my design. For example; are power lines enoughly thick for a high power amplifier? GND lines are suit for hums? Or etc...
Thanks.
Old 9th December 2003, 07:55 AM   #2
Dxvideo's Avatar
Sorry about that hitch, but I was under moderation so my every message were waiting for one day... I am sending my PCB again but in two pieces now..
Old 9th December 2003, 07:57 AM   #3
Dxvideo's Avatar
Please help me about this PCB designing. Because I had a lot of problem before (in my LM1876 gainclone) about GND connections.
Thanks in advance..
Old 9th December 2003, 12:41 PM   #4
bigparsnip is offline bigparsnip  United Kingdom
bigparsnip's Avatar
Hi, the board looks ok to me, as with the bridge mode of opperation there are no large grounde currents flowing from teh speaker -ve terminal to wory about. However, one thing which isn't clear to me is how you are going to attach the chips to a heat sink, as there is a large distance between them and the edge of your PCB.
Old 9th December 2003, 12:52 PM   #5
Dxvideo's Avatar
Its a good question.. I planned it for a week... I will attach LM3886s to a "U" shape aluminium thick part and will attach it to the board and after all attach all them to the heat sink. I know its hard to realise it but I will fix the heatsink to the back of the case so all other materials will hang on it... Is it clear? (in my poor English!)
But I'm still worrying about the GND and power lines. Because in my old experience (2 x LM1876) I had a lot of 100Hz noise because of GND lines (or they said that)... So u sure that the GNS lines doesnt make a ground loop?
Thanks...
Old 9th December 2003, 01:25 PM   #6
bigparsnip's Avatar
Hi, well I guess your ground lines are rather thin in places (see where I have circled below) so if there is a significant current flowing through the ground line, there will be a significant voltage created on the line, whihc my effect the zero reference point for the amp, and will generaly vary with the power supply hum (because of where trhe decoupling capacitors are connected) so you might want to try and find a way of routing the ground without any small traks. However, as this is a bridged amp, I'm not entirely sure you will still experience such problems, as both sides of the bridge will be experiencing simmilar noise, and it may be canceled out as common mode noise at the speaker output.
Old 9th December 2003, 08:43 PM   #7
mwmkravchenko is offline mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
My BPA200 PCB
Default Nice!
Wheres the whole pic????
Teasing us with only bits and pieces
Mark
Mark
www.kravchenko-audio.com
Old 9th December 2003, 09:01 PM   #8
Immo_G is offline Immo_G  Australia
From what i've gathered, there is very little current flow on the ground pin on the 3886, and i don't think its even there on the 3875? With the bridged circuit there isn't a ground return from speaker either, so ripple current from capacitors should be the only high current section.
Even still, i would make that part as circled a tad thicker, just because it does look very small, no scientific explanation
Old 9th December 2003, 09:12 PM   #9
tiroth is offline tiroth  United States
Low current requirement is all the more reason to have a kelvin return for the small-signal ground. Without seeing the whole PCB it is a little hard to imagine the grounding...
Old 9th December 2003, 10:47 PM   #10
moamps is offline moamps  Croatia
Separate grounds, make one star ground point.
My BPA200 PCBHide this!Advertise here!
bpa200 question ryan750 Chip Amps 14 28th June 2008 07:58 AM
BPA200 without DC-servo Professor Chip Amps 39 21st August 2007 08:49 PM
Bpa200 Opa549 Sub Amp Gcollier Chip Amps 8 2nd October 2006 11:58 PM
Bpa200 enter Chip Amps 2 3rd January 2006 08:16 PM
Copyright ©1999-2017 diyAudio
