TDA1552Q overdrive & other questions - diyAudio
Old 12th June 2013, 12:19 AM   #1
Default TDA1552Q overdrive & other questions
P { margin-bottom: 0.08in; } Hi, i have three questions on a 12 Volt 22 Watt amplifier (based on TDA1552Q).
  1. Does this chip have an inbuilt protection against overdrive...when the input goes above a certain level can I rely on it to cut out without circuit or speaker damage?
  2. Can anybody recommend a switching power supply...I've heard that HP Printers do a suitable one?
  3. I'm considering adding a simple, very basic tone-control circuit. Where would I find information?
First post on the forum, for any help, much obliged
Old 12th June 2013, 12:37 AM   #2
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Great chip - capable of really excellent sound.
No, no protection against overdriving the input - if you feed too great a signal in, it will clip. Heavily overdrive it and you could fry your tweeters. There won't be any circuit damage, it protects against that.
I'm using a close relative, TDA8566 with a Meanwell SMPSU (100W, 18V) - I am using a pair of LM350T regulators after that, reducing the supply to 15.5V (I turned up the voltage on the SMPSU to guarantee there's enough headroom).
The sound quality in my experience is limited by the quality of the supply. If you feed the chip direct from a SMPSU you'll get reasonable sound but not high-end. To get the best you need great HF filtering of the supply plus a very low impedance down to bass frequencies. I've achieved this in mine by adding plenty of paralleled caps to the output of my linear regs.
No experience of tone controls so will leave that aspect to others.
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Old 12th June 2013, 05:31 AM   #3
blu_glo is offline blu_glo  England
blu_glo's Avatar
Why are you thinking you are going to overdrive the input? What are you connecting the input to?
Old 12th June 2013, 11:30 AM   #4
On clipping...this amp actually clips at a lower volume just for one particular mp3 player...for other inputs I can turn input volume up much higher without a problem.
The supply problem...I'm currently using an old computer PSU...it's too bulky...considering a "Leicke" switching unit but it doesn't need to produce best-quality hifi.
Old 13th June 2013, 04:11 PM   #5
P { margin-bottom: 0.08in; } I've been advised to go for a „Meanwell“ S-60-15 - 60W 15V 4A and adjust the voltage down to 14,5.
Thing is, I may have to add capacitance to the output to deal with ripple on the line. As you're somewhat familiar with this product, I thought you might be able to advise me on what value or even within what sort of range of capacitance we're talking about. I'm a little out of my depth here. Obliged.
Old 19th June 2013, 10:20 AM   #6
P { margin-bottom: 0.08in; } To anybody with similar issues.. I found a suitable switching power supply for my needs... its a „Meanwell“ S-60-15 - 60W 15V 4A.....S-60-15 - 60W 15V 4A Enclosed Switching Power Supply
Doesn't need extra capacitors, filtering or anything else, works perfectly!
On mp3 clipping...I had volume on mp3 player turned to high...didn't realise.
In conclusion, please, somebody....a circuit for simple, passive bass/treble tone control
Old 22nd June 2013, 10:24 PM   #7
gootee is offline gootee  United States
Baxandall tone control:
Amplifier Tone Control
I always desire the most-accurate reproduction of the source. So I do not use any tone control.
Here is a thread about them:
Ultimatest Passive Tone Control Network based on James-Baxandall's topology wanted
Near the upper-right corner of the page is a link called "Search". You can search for Baxandall tone control schematic, or just tone control schematic. I usually also click on the "Show Posts" radio button, when searching.
Old 23rd June 2013, 09:22 PM   #8
P { margin-bottom: 0.08in; } With an attenuation of -20dB., I'm reconsidering fitting a passive tone control circuit. I need an expert oppinion....with an amp of 2 x 20 watts, how diminishing is a -20dB loss...are we talking 50% volume loss or...?
Obliged
Old 24th June 2013, 12:50 AM   #9
A factor of -20 dB is much worse than 50% less.
If it is dB power, then -20 dB is a factor of 0.01.
So I guess for dB Volts it must be a factor of 0.1. So, that would give only 10% remaining.
You might want to consider an active tone control. Or add an amplifier stage.
Old 24th June 2013, 01:53 AM   #10
abraxalito's Avatar
Why adjust the voltage down I wonder?
The ripple from a SMPSU is high frequency (quite unlike from a linear supply where its at double the mains frequency) so simply adding capacitance to the output probably won't help you. That's because at HF you need very low ESR and ESL (parasitic resistance and inductance) to reduce the ripple.
I use a lot of capacitance not to deal with PSU ripple, rather to deal with the signal-generated ripple which comes from the amp itself. Having lower audio band noise on the supply definitely helps the SQ.
Incidentally this post is tardy because for some reason the email notification's not working reliably.
How to improve marshall guitar amp with harsh overdrive? cretaceous Instruments and Amps 22 29th November 2012 06:46 PM
G&S Designs Redline Overdrive Series M10 Amp Robcrx Car Audio 1 9th February 2012 01:53 AM
TDA1552Q in computer speakers and headphone out ArtemKuchin Chip Amps 19 2nd July 2011 12:24 AM
TDA1552Q based computer speakers CivicProtection Chip Amps 21 28th December 2010 03:43 AM
Tda1552q Calamaro Chip Amps 1 12th September 2008 11:32 AM
Copyright ©1999-2017 diyAudio
