Buffered Volume Control - diyAudio
Old 8th June 2013, 01:00 AM   #1
Stormrider's Avatar
Send a message via AIM to Stormrider Send a message via MSN to Stormrider
Default Buffered Volume Control
This design is based on the Alps "Blue Velvet" RK027 pot. I'm using OPA2134 opamps and Rod Elliot's P05B power supply board with an Antek 10VA transformer in a Hammond case. It has turn on/off muting via a shorting relay (driven by the AUX supply on the P05B). It is DC coupled, and intended to be used with AC coupled source and amplifier.
AJ
Old 8th June 2013, 01:03 AM   #2
Stormrider's Avatar
Schematic:
AJ
Old 8th June 2013, 01:07 AM   #3
Stormrider's Avatar
Note that the RF bypass cap C1/C5 is too large as shown. Should be more like 22pF.
AJ
Old 9th June 2013, 12:34 PM   #4
Stormrider's Avatar
Is it that boring?
Any comments on the PCB design? Good, bad, ugly?
AJ
Old 9th June 2013, 04:01 PM   #5
No 4 is offline No 4  United States
Very cool project! Are those butt connectors on the input output connections? Its hard to tell on my phone.
Will.
Old 9th June 2013, 04:05 PM   #6
Stormrider's Avatar
On the board? No, I used 2pin Molex connectors for the signals and a 4pin molex for power (+15V, -15V, GND, AUX for relay). I used milspec shielded wire for the signals with solder sleeves for the shield terminations.
AJ
Old 9th June 2013, 04:27 PM   #7
Sorry I was referring to what appear to be blue heat shrink connections towards the rca side of the input output wiring.
Will.
Old 9th June 2013, 04:36 PM   #8
Stormrider's Avatar
Those are solder sleeves for the shield terminations. They are a small piece of blueish/clear heatshrink with a ring of solder and usually a wire that is shrunk down onto the cable. The solder melts joining the wire and shield.
AJ
Old 9th June 2013, 04:48 PM   #9
dmills is offline dmills  United Kingdom
What is the point of the input buffer on each channel? You have it set up for G=1, 47K input Z, but it is driving a 100K pot, so you could eliminate it and just go straight onto the top of the 100K pot.
Comes to that, why 100K? Seems more then a little on the high side.
What are the opamps? With a 100K pot you are asking for small DC level shifts as the pot is turned and worse, crackle once the pot ages if there is any significant input bias current present.
Old 9th June 2013, 05:02 PM   #10
Stormrider's Avatar
The opamps are OPA2134.
I used the 100K Alps because that's what was available without resorting to possible fakes on ebay, and with the JFET input opamps there is no DC on the pot, or the output.
You could eliminate the input buffer with the 100K pot, but it doesn't hurt anything.
AJ
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 07:20 PM
Remote control Passive Volume Control with Display ua100k Swap Meet 2 31st May 2011 03:01 PM
Replacing broken volume control with digital volume control Gunawan W Solid State 19 15th December 2010 10:46 AM
Valve buffered IGC - volume pot causes DC offset, crackling gaplessophile Chip Amps 29 3rd July 2009 12:02 AM
remote control motorised control for volume pot/knob CharlesY Parts 0 25th July 2005 11:12 AM
Copyright ©1999-2017 diyAudio
