A very cheap TDA2030 Kit
Old 23rd June 2013, 02:34 AM   #51
KMossman is offline KMossman  China
KMossman's Avatar
Send a message via Yahoo to KMossman A very cheap TDA2030 Kit
Originally Posted by Mihkus View Post
The hum can be caused by crap wires to chassis RCA or what ever connector you use..
Fully shielded audio wiring,
Hum could be from several sources; bad design, bad layout, wiring, poor components, poor grounding [most likely].............
If you have the time and interest, I'd suggest re-working the ground connections, then the wiring
Getting back into business, though non-audio related. Have excellent contacts for NEW [OEM] Russian and Chinese tubes. Custom chassis, and parts [MOQ applies]
Old 23rd June 2013, 03:47 AM   #52
redjr is offline redjr  United States
Originally Posted by KMossman View Post
I doubt I would buy from 'him'; the weight is wrong, no specs, no description, no specifics, and nothing to suggest he knows electronics
Something is fishy there for sure with that picture. I was going to buy the 2030 amp kit just for the case alone, but now I'll pass on it altogether after activexp's experience. I've got enough little amp modules to keep me busy for months and a move in 60 days. Things are getting nuts around here. There are much better foreign vendors to deal with and better products too.
redjr
Old 23rd June 2013, 08:07 AM   #53
activexp is offline activexp  United Kingdom
activexp's Avatar
Send a message via ICQ to activexp Send a message via AIM to activexp Send a message via MSN to activexp Send a message via Yahoo to activexp
Originally Posted by csom View Post
Sir, could you please try what I suggested at post# 38 ?
Yes I have tried that, thanks. Unfortunately it made no difference
Old 23rd June 2013, 11:49 AM   #54
csom is offline csom
csom's Avatar
Sorry to know.
The preamp/ tone control section usually needs a ripple free, dual regulated power supply. Even a very basic 7815 and 7915 regulator based PSU can fix the hum problem. But that requires some extra modding.
Anyway, all the best.
Warm regards, Som
Old 23rd June 2013, 01:00 PM   #55
crown300 is offline crown300
If you look closely, the "Vacuum Tube Amplifiers" for $25.27 is in the Books section, it's a book about Tube Amps.
A very cheap TDA2030 KitHide this!Advertise here!
Pearl Kit, Cheap rgheck Swap Meet 1 5th September 2009 03:30 PM
Cheap DAC kit Puggie Digital Source 8 22nd January 2007 11:27 AM
cheap HV kit. tade Planars & Exotics 2 25th November 2005 11:42 PM
What cheap kit should I buy? I need help! kingfootga Multi-Way 11 5th July 2002 12:26 AM
Copyright ©1999-2017 diyAudio
