A very cheap TDA2030 Kit
Old 8th June 2013, 10:53 AM   #21
activexp is offline activexp  United Kingdom
activexp's Avatar
Send a message via ICQ to activexp Send a message via AIM to activexp Send a message via MSN to activexp Send a message via Yahoo to activexp
I've made a start on the PCB and found a shortage of resistors. R2 and R9 (1.5R) are missing. Instead I have 2 extra 7.5K
All the caps were present and correct.
Old 8th June 2013, 11:56 AM   #22
csom is offline csom
csom's Avatar
Very nice! Keep posting. And all the very best.
Warm regards, Som
Old 11th June 2013, 06:14 AM   #23
KMossman is offline KMossman  China
KMossman's Avatar
Send a message via Yahoo to KMossman A very cheap TDA2030 Kit
I suggest replacing the input and output jacks - usually the stuff available in China is of dismal quality.
Probably it was initially designed to be used with a different power switch, then they found something cheaper and neglected to adjust the cabinet............
Otherwise a very good find!
Keen to know the results!
Getting back into business, though non-audio related. Have excellent contacts for NEW [OEM] Russian and Chinese tubes. Custom chassis, and parts [MOQ applies]
Old 11th June 2013, 05:07 PM   #24
overtheairbroadcast is offline overtheairbroadcast  Canada
Not including the the components with changed/different values -- how much of the kit pieces are you substituting and how much of it are you going to keep?
Just thought I would ask since you have it in front of you sometimes one can tell by the feel whether it is a cheap or good component.
Old 11th June 2013, 07:07 PM   #25
activexp's Avatar
This all depends on how well the amp works (if at all). Then I'll have to decide if it's worth 'upgrading'. I've almost finished populating the PCB and expect to have it ready for powering up in the next day or two.
I have a mystery about R14. It's marked on the PCB but not shown on the schematic or listed in the parts list. It is referred to on the 'instruction sheet' but it's in Chinese
Old 11th June 2013, 07:07 PM   #26
SarkkaS is offline SarkkaS  Finland
Bumped into this thread accidentally and subscribed...and now, after some very brief consideration, I put in an order. With shipping the total was $22.48 (USD), or in other words, about 17 . Cheap as soap, as they say in Finland..
Albeit the power supply is probably a little weak for this project, it's a good starting point. I have some transformers that might be of use for this project, so I might substitute for a better one later on, but the aim is to build this as it comes, as stock as possible, to emulate best a beginner's situation at building something like this.
-Sale
Old 12th June 2013, 08:13 PM   #27
I just got an email that stated that I'd have to pay another USD $22.31 to cover surprisingly high, increased postage costs for this delivery. I asked that my payment be refunded to my Paypal account and to forget it.
I'll just stick to my current LM4780 project...
-Sale
Old 12th June 2013, 08:45 PM   #28
activexp's Avatar
-Sale
That must be wrong as the amp weighs less than 1kg, probably about 1kg with packing. According to their shipping calculator, total shipping cost should be $20.66.
Anyway you did the right thing in cancelling as I've finished my amp and it doesn't work
There's a high hum level and distortion is about 99.9% using an old CD player as input source. I'm certain I have populated the board correctly so I don't know where to go from here seeing that I'm a total ignoramus on amp design.
There's the mystery of R14 as previously mentioned. I think this could be relevant. If only I understood Chinese! It looks to be on one of the LM324 pins.
And this too:
Any ideas anyone?
Old 12th June 2013, 08:54 PM   #29
activexp's Avatar
Thanks to Goldkenn for translation, R14 is a jumper wire. Might have known!
Old 13th June 2013, 01:14 PM   #30
activexp's Avatar
With the R14 jumper in place the amp actually works Sounds reasonable but there's some low level hum which could become annoying. The volume control is very sudden, either quiet or loud!
It could do with larger knobs to hide the nuts and oversize holes.
A very cheap TDA2030 KitHide this!Advertise here!
Pearl Kit, Cheap rgheck Swap Meet 1 5th September 2009 04:30 PM
Cheap DAC kit Puggie Digital Source 8 22nd January 2007 12:27 PM
cheap HV kit. tade Planars & Exotics 2 26th November 2005 12:42 AM
What cheap kit should I buy? I need help! kingfootga Multi-Way 11 5th July 2002 01:26 AM
Copyright ©1999-2017 diyAudio
