Looking for a finished amp to drive two Fostes FE127E 8ohm
Old 4th June 2013, 01:40 AM   #1
aussiebuddha is offline aussiebuddha  Australia
Default Looking for a finished amp to drive two Fostes FE127E 8ohm
Hi All.
I'm looking for a finished amp to drive my Fostex FE127E speakers (8ohm)
I used to have a trendsaudio TA-10 and the level of detail was great, but was very limited in the low end, sometimes it was too bright, and overall limited power.
It would be ideal if it has an extra channel (2.1 config) so I can add a sub later if I feel like it, but I'm not holding my breath for that one.
I've been looking at the TK2050 amps, but they seem to push less power in 8ohms than at 4.
Could you give me some recommendations, please?
Old 4th June 2013, 05:19 AM   #2
DUG is offline DUG  Canada
How much power were you looking for?
By "finished amp" do you mean a commercial product?
Or did you want someone to build one for you?
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 4th June 2013, 05:31 AM   #3
Looking for a finished commercial AMP.
Old 4th June 2013, 06:36 AM   #4
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally Posted by aussiebuddha View Post
... less power in 8ohms than at 4.
That is usually the case with any amp.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 4th June 2013, 06:40 AM   #5
Thanks Dave, then it becomes more important to have decent power.
Dave, since you have lots of experience with Fostex Drivers, how much power do you think it's required to drive my speakers, and get decent bass? (Regardless of the enclosure, which right now is a recommended by fostex, but planning to upgrade to a mini fonken)
Old 4th June 2013, 06:58 AM   #6
frugal-phile(tm)
planet10's Avatar
Quality of bass or extention?
We found that higher output impedance amps tended to work well (ie thee are most often tube amps)
dave
Old 4th June 2013, 07:00 AM   #7
dave
I'd say a combination of both, IMO the speaker, is quite bright, and could cover the bass if there's not much of it. (correct me if wrong)
Old 7th June 2013, 01:33 AM   #8
rjsaenz is offline rjsaenz  United States
I use the topping tp21 and tp22 to drive my fostex fe126en I like the way they sound. I think they get decent bass considering speaker is only 120mm.
Robert
Looking for a finished amp to drive two Fostes FE127E 8ohmHide this!Advertise here!
Help with XO for rarity - ATC PA75-260 8ohm STD drive units. Rewind Multi-Way 3 9th October 2012 03:55 PM
63watt class A into 8Ohm, 110watt semi-class A into 8Ohm, @ 20Khz 3rd harmonic -90dB FdW Solid State 47 31st December 2010 05:05 PM
8ohm resistor in series with 8ohm speakers for a 16ohm OT? Reidy- Tubes / Valves 8 11th January 2010 12:25 AM
T Amp Fostex FE127E plans st_eloi Full Range 4 1st May 2008 02:41 PM
fostes fe206e gonzii Full Range 4 31st July 2005 09:33 AM
