Tripath 2021b with preamp. help!
Old 2nd June 2013, 03:57 PM   #1
asbjoern is offline asbjoern
Unhappy Tripath 2021b with preamp. help!
Hey all DIY people.
I dont know if this has been up befor, but i apologize if so.
Sum up: -Basically i'm asking about the maximum input levels for a tripath based amp?-
I have a smsl sa-s3 tripath amp. it's based on the 2021b chip.
I am generally very impressed, but since i need to use it with a wide variation of mp3 players, ipods and smartphones, the sound is not always loud enough.
I believe this is due to the low output signals from the devices, rather than the amp itself.
My solution was to build this pre amp to boost those output signals:
JFET iPod preamplifier
when i completed it, I measured about 350% gain of the signal. Maybe a little high, but i tried it out. unfortunately it fried the amp pretty fast.
Now i'm waiting for a new amp to replace the old one. i adjusted the preamp so the gain is down to 200% now. but i'm a little nervous that it's still too high.?
So basically i'm asking about the maximum input levels for a tripath based amp?
Thanks//Asbjørn
Old 3rd June 2013, 03:51 PM   #2
Minion is offline Minion  Canada
Well , I don't know about your specific Class-D amp but most amps are built to handle a Line Level signal which is generally 0.7v to 1v .....
Old 7th June 2013, 10:19 AM   #3
a3aan92 is offline a3aan92  Belgium
This issue has been talked about alot in the 'Boominator' topic. Either lower the input resistance or if you don't want to modify the amp you can simply use a pre-amp. Portable headphone amps can do the job, for example the FiiO E6.
Tripath 2021b with preamp. help!Hide this!Advertise here!
Anyone tried this tube buffer/preamp for Tripath amps? dublin78 Class D 16 19th May 2018 12:48 PM
Why Tripath? Davey T Class D 4 25th May 2009 09:14 PM
Guitar Preamp = MIC Preamp = other preamp ,,are they all same? Paswa Instruments and Amps 1 12th March 2008 05:16 PM
Does the 2024 have magic the 2021b doesn't? dgo Class D 3 29th May 2005 09:16 PM
Some more Tripath Experiences MurrayP Solid State 7 4th May 2002 11:08 PM
